The new beta key has been updated, but whenever I download and install a new version, it never asks for it, and when I try to run the program it says something like "The key has expired as has been deleted, please restart the program."
So...what do I do now? How do I enter the new beta key to get the program to work? I just downloaded it about 4 days ago and already there are problems?
So how do I use the new beta key?
Re: So how do I use the new beta key?
I am having the same issue. Is there any kind of an update here so that we can get MakeMKV working?
I'd also love to know how to get the beta working again
This is ridiculous! Or are we all just missing something?
Okay so figured it out...
Set the date back on your computer a week or so...
Then goto that link in the other thread to the key that is good till August 2010, and copy it...
Open MakeMKV, it should open this time, it did on mine, then go up to the top and select Help, Then Register, and paste the key in...
Close makemkv, set your date back to normal, and it should run, did on mine... Hope that helps...
Worked perfectly, thanks so much!!
