Rest Stop:Dead Ahead Error
llennellV3
Post by llennellV3 »
http://www.imdb.com/title/tt0787505/
MakeMKV v1.5.6 beta win(x64-release) started
File 00000.mpls was added as title #0
Title #00009.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00003.mpls is equal to title 00000.mpls and was skipped
Title 00004.mpls is equal to title 00000.mpls and was skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00015.m2ts was added as title #1
Title #00016.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory E:/Rips
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occured while reading '/BDMV/STREAM/00000.m2ts' at offset '448659456'
Failed to save title 0 to file E:/Rips/title00.mkv
0 titles saved, 1 failed
Re: Rest Stop:Dead Ahead Error
Post by mike admin »
llennellV3 wrote:Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occured while reading '/BDMV/STREAM/00000.m2ts' at offset '448659456'
The disc is physically damaged, please check for scratches and try to gently clean it.
