Save selected tracks to one .mkv + generate chapters
dma_k
#1 Post by dma_k » Sun Aug 26, 2018 12:13 pm
Dear MakeMKV team,
I have a DVD which MakeMKV recognizes as DVD with several independent chapters. However I would like to save them into one MKV file + have chapters automatically generated. How can I go this? Several forum threads (one, two, three) suggest to use MKV tools to do this, which I use at the moment. However then I would need to create chapters file by hand. Can MakeMKV save all selected tracks to one MKV so one can skip manual "append" step? Can MakeMKV also generate chapters file automatically?
Re: Save selected tracks to one .mkv + generate chapters
#2 Post by d00zah » Sun Aug 26, 2018 2:09 pm
Create the individual .mkvs with 'MakeMKV' & use 'mkvtoolnix' to join them into a single file.
#3 Post by Woodstock » Sun Aug 26, 2018 4:32 pm
Although that will not create a chapter file to go with it.
I believe the chapter editor in mkvmerge will allow you to create one, but I haven't tried that.
dma_k
#4 Post by dma_k » Sun Aug 26, 2018 7:14 pm
@d00zah: I am pretty OK to use mkvtoolnix-gui.exe to append MKVs. However chapter generation does not happen magically. The GUI has chapter editor, but (as far as I know) it allows only manual creation/editing.
#5 Post by d00zah » Sun Aug 26, 2018 7:39 pm
dma_k wrote: Sun Aug 26, 2018 7:14 pm @d00zah: I am pretty OK to use mkvtoolnix-gui.exe to append MKVs. However chapter generation does not happen magically. The GUI has chapter editor, but (as far as I know) it allows only manual creation/editing.
I haven't done this recently, so was thinking each .mkv would have a single chapter mark that would carry through the concatenation... but it seems that isn't the case. That said, if it were my project, I might use the chapter editor to add a chapter mark at the beginning/end of the 1st part, at the end of each subsequent part & then join the parts. Seems easier (more precise?) than adding chapters post-join? Unsure how else accomplish the chapters otherwise. YMMV
mreedelp2
#6 Post by mreedelp2 » Sun Aug 26, 2018 8:01 pm
Use MKVToolNix GUI. Add the files to be appended together, but before creating the new file, select the Output tab. On the right side near the bottom there is selection for Generating Chapters. Click on it and choose "One chapter for each appended file". Then rip.
#7 Post by d00zah » Sun Aug 26, 2018 8:26 pm
mreedelp2 wrote: Sun Aug 26, 2018 8:01 pm Use MKVToolNix GUI. Add the files to be appended together, but before creating the new file, select the Output tab. On the right side near the bottom there is selection for Generating Chapters. Click on it and choose "One chapter for each appended file". Then rip.
Wonderful! MUCH better. Thx! Adding this to my notes.
dma_k
#8 Post by dma_k » Sun Aug 26, 2018 8:52 pm
Fantastic! Thanks for the tip!
#9 Post by mike admin » Sun Sep 02, 2018 10:10 pm
If your source is DVD then you actually can do it from MakeMKV using http://www.makemkv.com/manualdvd/ . But mkvtoolnix is probably an easier choice.
