UHD drives
bodieiv
Re: UHD drives
Post by bodieiv » Fri Aug 24, 2018 9:55 pm
Can ASUS BW-16D1HT internal drive be outfitted as external and be compatible for MAC? It only shows windows.
jonghotti
Re: UHD drives
Post by jonghotti » Sat Aug 25, 2018 12:50 am
Absolutely yes, PM sent.
jhughy2010
Re: UHD drives
Post by jhughy2010 » Sat Aug 25, 2018 3:53 pm
I'm trying to find a retailer that'll have some of these drives in stock but it's proving to be difficult unless I'm willing to spend a little more than I want to. Any ideas?
Re: UHD drives
Post by d00zah » Sat Aug 25, 2018 4:07 pm
jhughy2010 wrote: Sat Aug 25, 2018 3:53 pm I'm trying to find a retailer that'll have some of these drives in stock but it's proving to be difficult unless I'm willing to spend a little more than I want to. Any ideas?
viewtopic.php?f=16&t=17829
MacManiac
Re: UHD drives
Post by MacManiac » Sun Aug 26, 2018 5:18 pm
Hey, everyone! I'm new here, but I have a quick question.
I plan on getting a WH16NS40 for 4K ripping/playback, but if the newer models have an SVC code of NS50, will I still have to worry about potentially downgrading from firmware 1.03, or is that only a concern for the older SVC codes?
st4evr
Re: UHD drives
Post by st4evr » Sun Aug 26, 2018 5:59 pm
MacManiac wrote: Sun Aug 26, 2018 5:18 pm Hey, everyone! I'm new here, but I have a quick question.
You are misunderstanding/confusing yourself on how this currently works. Let’s clearly break it down a bit for you:
1.If you are going to buy one of the LG drives you NEED one with SVC NS50. ALL new LG drives that are UHD Friendly WILL have this code. It’s one of the clear requirements as stated over and over in this thread/post for LG UHD Friendly drives. OLDER drives that are incompatible for this purpose are the ones that do NOT have a SVC NS50.
2. Since the discovery of the loophole manufacurers of these UHD Friendly drives have begun to sell them with patched firmware. In your case for that LG drive it would be with 1.03. LG has been quick and adamant about this. You are kinda late to this game, but there are people in this forum that can help. Example:
viewtopic.php?f=16&t=17831
So keep on reading and doing your research to ensure you take the correct steps in all this.
MacManiac
Re: UHD drives
Post by MacManiac » Sun Aug 26, 2018 6:10 pm
st4evr wrote: Sun Aug 26, 2018 5:59 pm 1.If you are going to buy one of the LG drives you NEED one with SVC NS50. ALL new LG drives that are UHD Friendly WILL have this code. It’s one of the clear requirements as stated over and over in this thread/post for LG UHD Friendly drives. OLDER drives that are incompatible for this purpose are the ones that do NOT have a SVC NS50.
Thank you so much for clearing that up. I figured I had to have been missing something.
powderkeg
Re: UHD drives
Post by powderkeg » Wed Aug 29, 2018 12:59 pm
Just bought an Asus BW-16D1H-U PRO and it spits out UHD disks, unable to read them at all, just like my other drives. Have I wasted my money or is there a way to get it working?
Re: UHD drives
Post by Woodstock » Wed Aug 29, 2018 1:28 pm
The Asus BW-16D1H-U is listed as not supporting UHD on the first page of this topic. I know, I reported it.
The drive in the USB3 enclosure is not one of the BDXL-compatible units Asus sells, despite having a similar catalog number.
bw001
Re: UHD drives
Post by bw001 » Thu Aug 30, 2018 8:53 pm
powderkeg wrote: Wed Aug 29, 2018 12:59 pm Just bought an Asus BW-16D1H-U PRO and it spits out UHD disks, unable to read them at all, just like my other drives. Have I wasted my money or is there a way to get it working?
Woodstock wrote: Wed Aug 29, 2018 1:28 pm The Asus BW-16D1H-U is listed as not supporting UHD on the first page of this topic. I know, I reported it.
If you can't return that drive, you can replace the drive inside with a compatible UHD friendly drive (ASUS BW-16D1HT or LG WH16NS40) after flashing the correct firmware to the new drive.
You can sell the incompatible drive (as an internal Blu-ray drive) after removing it.
To remove the drive from that enclosure, peel back the 2 rubber feet on bottom toward the rear of the drive and remove the 2 screws under those feet. It will then be easy to take apart the enclosure and remove the drive. It's also easy to get it back together.
MacManiac
Re: UHD drives
Post by MacManiac » Thu Aug 30, 2018 11:53 pm
I just received a WH16NS40 from jonghotti, but what SATA to USB 3.0 cord do I need? The 2.5" or the 3.5"?
tvguy7
Re: UHD drives
Post by tvguy7 » Fri Aug 31, 2018 2:00 am
I have a ASUS BW-16D1HT drive that has worked for me for over a year and now discs do not show up in windows. My assumption is that something went wrong with the optical laser. I've tried all sorts of things to get it to work with no luck. Has any ever replaced the laser diode in one of these drives. I have tried to use DVD cleaners in hopes there was just some dust on the laser element. I have tried to remove the drive completely from windows and reinstall. I have tried to blow air inside hoping to dislodge some dust. Nothing has worked. Any other suggestions out there? Any help would be appreciated. Are there any "friendly" drives left that are easy to get?
jonghotti
Re: UHD drives
Post by jonghotti » Fri Aug 31, 2018 8:56 am
MacManiac wrote: Thu Aug 30, 2018 11:53 pm I just received a WH16NS40 from jonghotti, but what SATA to USB 3.0 cord do I need? The 2.5" or the 3.5"?
Neither, check your email please, your enclosure will be there Sunday morning :-)
st4evr
Re: UHD drives
Post by st4evr » Fri Aug 31, 2018 10:18 am
tvguy7 wrote: Fri Aug 31, 2018 2:00 am Are there any "friendly" drives left that are easy to get?
These guys may be able to help with a new drive:
jonghotti
Re: UHD drives
Post by jonghotti » Fri Aug 31, 2018 11:10 am
st4evr wrote: Fri Aug 31, 2018 10:18 am
Those guys ARE able to ship up to 19 drives from the West coast fulfillment center alone, by the close of business today, 31 August 2018.
