I just purchased the Avatar 3D Blu-Ray Disc from Best Buy today and I can read the disk in two different Blu-Ray drives and it also plays in an older Blu-Ray player to my TV. I just want to RIP the 2D version but every time I try to make the MKV file I get an error at about 1:10 into the disc. I have tried backing up as well and it also fails. I have tried many times selecting different combinations of files and nothing works.
The main disc contains both the 3D and 2D versions.
What info is required to try and solve this issue? I'll email the dumped file that was created.
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/generic.svq
Saved BD+ dump file as C:\Users\owner/.MakeMKV/dump_Avatar_FCD1FE50149BCB19.tgz
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Title #00002.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00852.mpls was added as title #0
The source file '00003.clpi' is corrupt or invalid at offset #1100, attempting to work around
The source file '00003.clpi' is corrupt or invalid at offset #1101, attempting to work around
The source file '00003.clpi' is corrupt or invalid at offset #1102, attempting to work around
The source file '00003.clpi' is corrupt or invalid at offset #1103, attempting to work around
The source file '00004.clpi' is corrupt or invalid at offset #1100, attempting to work around
The source file '00004.clpi' is corrupt or invalid at offset #1101, attempting to work around
The source file '00004.clpi' is corrupt or invalid at offset #1102, attempting to work around
The source file '00004.clpi' is corrupt or invalid at offset #1103, attempting to work around
Title #00001.mpls was skipped
Title 00851.mpls is equal to title 00852.mpls and was skipped
File 00804.mpls was added as title #1
Title #00194.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00193.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00803.mpls is equal to title 00852.mpls and was skipped
Title 00800.mpls is equal to title 00852.mpls and was skipped
Title #00202.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00853.mpls is equal to title 00852.mpls and was skipped
Title 00850.mpls is equal to title 00852.mpls and was skipped
Title 00802.mpls is equal to title 00852.mpls and was skipped
Title 00854.mpls is equal to title 00804.mpls and was skipped
Title 00801.mpls is equal to title 00852.mpls and was skipped
Title #00019.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00068.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00065.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00066.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00069.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00047.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00064.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00067.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 2 titles into directory C:/Video/Avatar
Failed to save title 0 to file C:/Video/Avatar/Avatar_t00.mkv
Failed to save title 1 to file C:/Video/Avatar/Avatar_t01.mkv
0 titles saved, 2 failed
Saving 1 titles into directory C:/Video/Avatar
0 titles saved, 1 failed
Avatar Limited 3D Edition Blu-Ray Disc **SOLVED**
Last edited by monkeymindboy on Sun Aug 19, 2018 11:18 pm, edited 1 time in total.
Windows 10 Pro
LG WH16NS40 - UHD Friendly
Asus BW-16D1HT - UHD Friendly
LG WH16NS40 - External Drive - Blu-Ray
HD/DVD - XBOX360 - External Drive
Re: Avatar Limited 3D Edition Blu-Ray Disc
A little more info. I deselected all subtitles and the disc processed at little further past a minute 10 seconds to about a minute 45 seconds but then I received the following errors.
It could be just a bad disc.
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 1162205184, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 1194473472, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 1408622592, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 1453578240, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 1796450304, attempting to work around
Windows 10 Pro
First thing to try is to clean the discs. I use a 50/50 solution of water and alcohol. I use that with a clean microfiber cloth. Even though the discs may look clean, many times they are not. Good Luck.
Thanks for the tip. I just tried cleaning with a 50/50 solution and I still get the error.
I may just take it back tomorrow and get another version.
Thanks.
Thanks.
Windows 10 Pro
Re: Avatar Limited 3D Edition Blu-Ray Disc ** SOLVED **
Downgraded to 1.12.2 and just as a precautionary measure I deselected the attachment file (I normally select) and I successfully ripped the file.
Windows 10 Pro
Re: Avatar Limited 3D Edition Blu-Ray Disc **SOLVED**
Yes! I was having the same exact issues, similarly with Avatar. 1.12.3 was unable to rip with subtitles enabled - always this error:
Need the forced subtitles for this movie. Reverting to 1.12.2 solves the issue. Not sure about other titles.
Exception: Error in p->FetchFrames(1,false)
Thanks for updating. Was trying to rip Avatar on 1.14.1 and was causing similar errors. Downgraded to 1.12.2 and it worked.monkeymindboy wrote: ↑Sun Aug 19, 2018 11:17 pmDowngraded to 1.12.2 and just as a precautionary measure I deselected the attachment file (I normally select) and I successfully ripped the file.
As the version history indicates, this is fixed in 1.14.2. I ripped the same Avatar disc without issue.
