Deadpool 2 artifacts
turkeycat
Post by turkeycat »
Looks like Deadpool 2 will not rip correctly without artifacts. Is there an update for this issue?
Re: Deadpool 2 artifacts
Did you get any error messages about "No FUTs"? If so, did you send the file that was generated to svq@makemkv.com as instructed?
turkeycat
Post by turkeycat »
There are no errors, just poor output. I have attached an example frame.
screen grab
screen grab
Screen Shot 2018-08-22 at 3.31.06 PM.png (404.71 KiB) Viewed 7265 times
None of the other docs I have run recently have done this.
turkeycat
Post by turkeycat »
OK, not sure what is different with this version than others but, it appears this is only a playback issue with the player I was using. Using a new version of VLC the artifacts go away.
