HDR MKV not working
optimizer
HDR MKV not working
Post by optimizer » Tue Aug 21, 2018 9:08 pm
got a new pc put together (i5-8600, GTX1070 ti connected HDMI direct to Samsung KS8000) and some things work and look great with HDR. i've got a couple sample videos from http://4kmedia.org/, a ts file and an mp4 file. those both show in HDR using VLC and MPC-BE. i've got the tv's UHD color setting to on (this has to be on for youtube to make HDR an option), and windows has HDR and WCG set to on. i can't get an MKV to show properly with HDR though. the codec info on my MKV file says color space is ITU-R BT.2020
EPiPH0N3
Re: HDR MKV not working
Post by EPiPH0N3 » Wed Aug 22, 2018 12:53 am
You should probably have a look at these:
http://madvr.com/
https://forum.doom9.org/showthread.php?t=146228
optimizer
Post by optimizer » Wed Aug 22, 2018 2:52 am
thanks. i actually came across this guide and this guide, so i'm going to be using madvr soon.
optimizer
Post by optimizer » Wed Aug 22, 2018 7:49 pm
optimizer wrote: Wed Aug 22, 2018 2:52 am thanks. i actually came across this guide and this guide, so i'm going to be using madvr soon.
it kinda worked. i saw colors become more saturated, but it seems like the tv isn't putting out as much light. when the HDR is working, bright lights are intense. the MKV with the madvr settings didn't have the luminance i've seen with HDR.
joshuagoard
Post by joshuagoard » Mon Dec 31, 2018 4:04 am
Just put the MKV files on an external drive and plug it into the tv and use the built in video app...problem solved.
