Kenshin 12 DVD collection. One single disk failing...
vree360
#1 Post by vree360 » Mon Aug 20, 2018 10:18 am
So I'm making a backup of my Box collection of Kenshin (Samurai X) cotnaining 12DVD's.
I'm using makemkv to create a mkv of every single disc. Not changing a single setting.
But it always fails close to the end on disc 3 of the collection. All the other discs went fine.
Extra information:
I successfully made an ISO file of all 12 DVD discs. All the iso's are bootable and play fine. Same with DVD/ISO 3, played it in my ps4 nd watched it untill the end. Also the ISO creating was not a problem.
Still makemkv can't successfully create an MKV file. Tried both with the original DISC and the ISO.
Any ideas or other ways to complete my rip?
Re: Kenshin 12 DVD collection. One single disk failing...
#2 Post by Woodstock » Mon Aug 20, 2018 3:12 pm
A debug log (FAQ link in my signature) would be helpful to see what kind of error is being encountered.
vree360
#3 Post by vree360 » Mon Aug 20, 2018 4:57 pm
Woodstock wrote: Mon Aug 20, 2018 3:12 pm A debug log (FAQ link in my signature) would be helpful to see what kind of error is being encountered.
Debug log started at Mon Aug 20 16:43:04 2018 , written by MakeMKV v1.12.3 win(x64-release)
001005:0000 MakeMKV v1.12.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Dimi/MakeMKV_log.txt
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
003028:0000 Title #1 was added (40 cell(s), 3:10:09)
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003025:0000 Title #2 has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=2 pgcn=1 hash=E8310777DE476563
003019:0000 Cells 3-end were skipped due to cell commands (structure protection?)
003025:0000 Title #2/0/1 has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at 0RYoYFFaMJGPXta3esacRoBM:0
005014:0000 Saving 1 titles into directory I:/Kenshin dvd rips/DVD 3
001002:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
005003:0000 Failed to save title 0 to file I:/Kenshin dvd rips/DVD 3/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Mon Aug 20 16:57:06 2018
vree360
#4 Post by vree360 » Mon Aug 20, 2018 5:20 pm
IFO files:
https://wetransfer.com/downloads/efb09d ... 923/3d1afb
DISC LABEL:
GOD3
MakeMKV v1.12.3
If needed I can share the ripped iso version. But again before someone says it. Like I said before I tried MakeMKV on both the ISO and the original DVD with the exact same result at the exact same moment.
I even tried 2 different ISO making tools to verify it isn't just the disk. One that verifies every single sector. And all of them where OK, not a single bad one.
And as stated before whatched all episodes on that disc in my PS4 and that worked fine.
#5 Post by Woodstock » Mon Aug 20, 2018 8:29 pm
You could try going back to version 1.12.2; there have been some issues with 1.12.3 on SOME disks.
vree360
#6 Post by vree360 » Mon Aug 20, 2018 8:36 pm
Woodstock wrote: Mon Aug 20, 2018 8:29 pm You could try going back to version 1.12.2; there have been some issues with 1.12.3 on SOME disks.
Where can I download these old versions?
#7 Post by Woodstock » Mon Aug 20, 2018 11:31 pm
vree360
#8 Post by vree360 » Tue Aug 21, 2018 6:45 pm
Woodstock wrote: Mon Aug 20, 2018 11:31 pm https://makemkv.com/download/old/
Can't use the older version needs a registration code...
vree360
#9 Post by vree360 » Tue Aug 21, 2018 6:58 pm
vree360 wrote: Tue Aug 21, 2018 6:45 pm
EDIT: Never mind found the key. Testing now.
EDIT: Nope still no luck using that version. Will have to take do with HandBrake for now for that one disk.
