MakeMKV not working with "Invictus" - Region A
rilopes
Post by rilopes »
Have already used this wonder app. several times. But with "Invictus" ( blu-ray commecial version, region A ) it's not working.
I've ripped disk to HD keeping protection and load the ISO with UltraISO or Daemon Tools virtual drive. When I try to process it in makeMKV I'm getting this log:
" MakeMKV v1.5.6 beta win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occured while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occured while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occured while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occured while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - NOT READY:INCOMPATIBLE MEDIUM INSTALLED' occured while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occured while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom2' "
The screen goes attached.
Thanks for your support !
dirio49
Re: MakeMKV not working with "Invictus" - Region A
Post by dirio49 »
Makemkv only work with decrypted iso and the real disk on the drive.
The only way to open that disk is wtih anydvd or passkey running.
or if you have the vid or vud of the disk
later
Post by mike admin »
You should have used "backup" command in MakeMKV to preserve VID from the disc. See http://www.makemkv.com/faq/item/11/catid/6
rilopes
Post by rilopes »
Yeah, right ! My bad...
I didnt realize the copy was unnencrypted. Now I'll try to find the VID ...
Thanks again !
