Mozart - Complete Symphonies - Karl Bohm
ubertrout
Post by ubertrout » Mon Aug 20, 2018 2:07 pm
Hi, I'm trying to use MakeMKV to rip Mozart: Complete Symphonies, Karl Bohm conducting the Berlin Philharmonic. It's a brand new release: https://www.amazon.com/Mozart-Complete- ... B07C5K7RBN
The rip runs for over an hour but at about 95% it finishes with an error and a 29GB unusable MKV (the disc is 38GB). I'm ripping using the FLAC profile. I don't know if the disc's unique attributes are a factor? it's 12 hours 33 minutes of 24-bit/192khz DTS-HD MA audio, with essentially no video content beyond menus.
I've used MakeMKV to rip similar discs without a problem, but this is probably the longest one I've tried. What other information would be helpful?
Re: Mozart - Complete Symphonies - Karl Bohm
Post by Woodstock » Mon Aug 20, 2018 3:07 pm
What error? (debug log information would be VERY helpful, see FAQ link in signature)
ubertrout
Post by ubertrout » Tue Aug 21, 2018 3:04 am
Here you go. There's actually two logs here - I ripped the first time (succesfully) using default settings, which I didn't care about, and then re-ran it with FLAC, which crashed as expected.
Debug log started at Tue Aug 21 00:40:58 2018 , written by MakeMKV v1.12.2 win(x64-release)
001005:0000 MakeMKV v1.12.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Redacted/MakeMKV_log.txt
005075:0000 The new version 1.12.3 is available for download at http://www.makemkv.com/download/
DEBUG: Code 2365587456 at #JEH3khy]yJ.Vdvo:121271065
DEBUG: Code 2147483648 at #JEH3khy]yJ.Vdvo:29396483
DAFD=PAAAADAAAAEABDQkEHgACAQ==
DCE=uHSngv6OJ1++duCJcqMb+8vZhu1tl4YZK9KjVepihZHc73aTzKOaEwftwfTwbJ0TdjkACMRB12LoLKarDr12abYVGXqLPKJRoAurWo0Jgj1v7MR+oN8XZ9lFbZvj8B4Pbb/wD8roPS9thtBuMfuXJeYy/Kt2ZOXvuw==
DCE=/v7+/v6MsVzeAVFlXpJv9bUyF9GxPN+td/7GcZaZmZ1xrcWvuqdVQf4atLhj1TWSjFDcuLgLeXOMPgg+/LZRXYgKqO/O8qaJcAbWeQtczccwzj+le0SRSk7JI+9gWaH/kY1qrH0sHQ9AQi6s17ntZOA3356AJClL5g==
DISCID=3BD9101DE4F95ABC8673EAD88D74BAC625F2E57F
003307:0000 File 00000.mpls was added as title #0
005014:0000 Saving 1 titles into directory N:/Video/MOZART_THE_SYMPHONIES_-_KARL_BÖHM
005001:0308 File N:/Video/MOZART_THE_SYMPHONIES_-_KARL_BÖHM/MOZART_THE_SYMPHONIES_-_KARL_BÖHM_t00.mkv already exist. Do you want to overwrite it?
AV sync issues in N:/Video/MOZART_THE_SYMPHONIES_-_KARL_BÖHM/MOZART_THE_SYMPHONIES_-_KARL_BÖHM_t00.mkv
AV sync in 1 at 0:22:33.352 (7.666ms) : short audio gap was removed, audio skew is -8ms
AV sync in 1 at 0:30:02.792 (17ms) : audio gap - 1.593 missing frame(s)
AV sync in 1 at 0:43:06.584 (7ms) : short audio gap was removed, audio skew is -7ms
AV sync in 1 at 0:57:46.456 (14ms) : audio gap - 1.312 missing frame(s)
AV sync in 1 at 1:09:21.157 (6ms) : short audio gap was removed, audio skew is -6ms
AV sync in 1 at 1:19:44.773 (13ms) : audio gap - 1.218 missing frame(s)
AV sync in 1 at 1:38:55.930 (3.333ms) : short audio gap was removed, audio skew is -3.333ms
AV sync in 1 at 1:51:02.656 (6ms) : short audio gap was removed, audio skew is -9.333ms
AV sync in 1 at 2:03:35.402 (14.666ms) : audio gap - 1.375 missing frame(s)
AV sync in 1 at 2:15:18.110 (3.333ms) : short audio gap was removed, audio skew is -3.333ms
AV sync in 1 at 2:23:56.628 (0.666ms) : short audio gap was removed, audio skew is -4ms
AV sync in 1 at 2:34:00.222 (12.333ms) : audio gap - 1.156 missing frame(s)
AV sync in 1 at 2:45:21.912 (6.333ms) : short audio gap was removed, audio skew is -6.333ms
AV sync in 1 at 2:57:53.656 (13.333ms) : audio gap - 1.25 missing frame(s)
AV sync in 1 at 3:20:32.020 (10ms) : short audio gap was removed, audio skew is -10.333ms
AV sync in 1 at 3:36:33.972 (19.333ms) : audio gap - 1.812 missing frame(s)
AV sync in 1 at 3:49:39.766 (3.666ms) : short audio gap was removed, audio skew is -3.666ms
AV sync in 1 at 4:03:26.582 (13.666ms) : audio gap - 1.281 missing frame(s)
AV sync in 1 at 4:21:40.685 (2.333ms) : short audio gap was removed, audio skew is -2.333ms
AV sync in 1 at 4:34:33.457 (4ms) : short audio gap was removed, audio skew is -6.333ms
AV sync in 1 at 4:46:13.147 (14.666ms) : audio gap - 1.375 missing frame(s)
AV sync in 1 at 5:04:52.274 (3.333ms) : short audio gap was removed, audio skew is -3.333ms
AV sync in 1 at 5:17:34.035 (1ms) : short audio gap was removed, audio skew is -4.333ms
AV sync in 1 at 5:41:53.683 (14.533ms) : audio gap - 1.362 missing frame(s)
AV sync in 1 at 6:01:22.861 (5.333ms) : short audio gap was removed, audio skew is -5.333ms
AV sync in 1 at 6:21:29.058 (13ms) : audio gap - 1.218 missing frame(s)
AV sync in 1 at 6:30:48.625 (7ms) : short audio gap was removed, audio skew is -7ms
AV sync in 1 at 6:41:58.289 (12ms) : audio gap - 1.125 missing frame(s)
AV sync in 1 at 7:16:04.338 (5.666ms) : short audio gap was removed, audio skew is -6.666ms
AV sync in 1 at 7:33:20.373 (3ms) : short audio gap was removed, audio skew is -9.666ms
AV sync in 1 at 7:42:32.917 (17.666ms) : audio gap - 1.656 missing frame(s)
AV sync in 1 at 8:03:55.206 (9ms) : short audio gap was removed, audio skew is -9ms
AV sync in 1 at 8:30:49.808 (19.333ms) : audio gap - 1.812 missing frame(s)
AV sync in 1 at 9:08:17.064 (1.333ms) : short audio gap was removed, audio skew is -2.333ms
AV sync in 1 at 9:17:04.591 (7ms) : short audio gap was removed, audio skew is -9.333ms
AV sync in 1 at 9:39:11.908 (18ms) : audio gap - 1.687 missing frame(s)
AV sync in 1 at 10:04:27.431 (4.666ms) : short audio gap was removed, audio skew is -4.666ms
AV sync in 1 at 10:22:14.497 (4.666ms) : short audio gap was removed, audio skew is -9.333ms
AV sync in 1 at 10:47:01.974 (18ms) : audio gap - 1.687 missing frame(s)
AV sync in 1 at 11:12:17.497 (4.666ms) : short audio gap was removed, audio skew is -4.666ms
AV sync in 1 at 11:37:29.998 (14.333ms) : audio gap - 1.343 missing frame(s)
AV sync in 1 at 12:04:41.638 (3.333ms) : short audio gap was removed, audio skew is -3.333ms
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
005015:0000 Saving 1 titles into directory N:/Video/MOZART_THE_SYMPHONIES_-_KARL_BÖHM using profile 'FLAC' from file 'C:\Program Files (x86)\MakeMKV/appdata.tar:flac.mmcp.xml'
FFENC048: option compression_level=5
FFDEC001: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
FFDEC036: [dca @ 000002170ceae5a0] Warning: not compiled with thread support, using thread emulation
FFENC048: [flac @ 000002171ebe9eb0] Warning: not compiled with thread support, using thread emulation
FFENC048: [flac @ 000002171ebe9eb0] compression: 5
FFENC048: [flac @ 000002171ebe9eb0] lpc type: Levinson-Durbin recursion with Welch window
FFENC048: [flac @ 000002171ebe9eb0] prediction order: 1, 8
FFENC048: [flac @ 000002171ebe9eb0] order method: estimate
FFENC048: [flac @ 000002171ebe9eb0] partition order: 0, 8
FFENC048: [flac @ 000002171ebe9eb0] block size: 16384
FFENC048: [flac @ 000002171ebe9eb0] lpc precision: 15
FFDEC002: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 1 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 0:11:31.690 (0.333ms) : audio gap was filled with silence
FFDEC003: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 2 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 0:22:33.344 (7.666ms) : audio gap was filled with silence
FFDEC004: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 3 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 0:30:02.792 (9ms) : audio gap was filled with silence
FFDEC005: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 4 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 0:43:06.577 (7ms) : audio gap was filled with silence
FFDEC006: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 5 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 0:57:46.456 (7ms) : audio gap was filled with silence
FFDEC007: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
AV sync in 1 at 1:09:21.151 (6ms) : audio gap was filled with silence
FFDEC008: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 7 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 1:19:44.773 (7ms) : audio gap was filled with silence
FFDEC009: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 8 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 1:38:55.926 (3.333ms) : audio gap was filled with silence
FFDEC010: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 9 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 1:51:02.650 (6ms) : audio gap was filled with silence
FFDEC011: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 10 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 2:03:35.402 (5.333ms) : audio gap was filled with silence
FFDEC012: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 11 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 2:15:18.106 (3.333ms) : audio gap was filled with silence
FFDEC013: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 12 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 2:23:56.627 (0.666ms) : audio gap was filled with silence
FFDEC014: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 13 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 2:34:00.222 (8.333ms) : audio gap was filled with silence
FFDEC015: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 14 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 2:45:21.905 (6.333ms) : audio gap was filled with silence
FFDEC016: [dca @ 000002176bc6b880] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 15 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 2:57:53.656 (7ms) : audio gap was filled with silence
FFDEC017: [dca @ 000002171ebdee10] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 16 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 3:07:49.257 (0.333ms) : audio gap was filled with silence
FFDEC018: [dca @ 000002171ebdf730] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 17 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 3:20:32.010 (10ms) : audio gap was filled with silence
FFDEC019: [dca @ 000002171ebde4f0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 18 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 3:36:33.972 (9ms) : audio gap was filled with silence
FFDEC020: [dca @ 000002170c762680] Warning: not compiled with thread support, using thread emulation
AV sync in 1 at 3:49:39.762 (3.666ms) : audio gap was filled with silence
FFDEC021: [dca @ 000002171ebdc500] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 20 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 4:03:26.582 (10ms) : audio gap was filled with silence
FFDEC022: [dca @ 000002171ebdd2b0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 21 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 4:21:40.682 (2.333ms) : audio gap was filled with silence
FFDEC023: [dca @ 000002171ebdc070] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 22 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 4:34:33.453 (4ms) : audio gap was filled with silence
FFDEC024: [dca @ 000002171ebdc070] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 23 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 4:46:13.147 (8.333ms) : audio gap was filled with silence
FFDEC025: [dca @ 000002171ebdd740] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 24 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 5:04:52.270 (3.333ms) : audio gap was filled with silence
FFDEC026: [dca @ 000002171ebdd2b0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 25 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 5:17:34.034 (1ms) : audio gap was filled with silence
FFDEC027: [dca @ 000002171ebde980] Warning: not compiled with thread support, using thread emulation
AV sync in 1 at 5:41:53.683 (10.2ms) : audio gap was filled with silence
FFDEC028: [dca @ 000002171ebddbd0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 27 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 6:01:22.855 (5.335ms) : audio gap was filled with silence
FFDEC029: [dca @ 000002171ebdd740] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 28 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 6:21:29.058 (7.668ms) : audio gap was filled with silence
FFDEC030: [dca @ 000002171ebdf2a0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 29 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 6:30:48.618 (7.002ms) : audio gap was filled with silence
FFDEC031: [dca @ 000002170ce0d7c0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 30 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 6:41:58.289 (5.002ms) : audio gap was filled with silence
FFDEC032: [dca @ 000002170d262080] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 31 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 6:51:59.894 (1.002ms) : audio gap was filled with silence
FFDEC033: [dca @ 000002170d264e20] Warning: not compiled with thread support, using thread emulation
AV sync in 1 at 7:16:04.332 (5.668ms) : audio gap was filled with silence
FFDEC034: [dca @ 000002170d263be0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 33 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 7:33:20.370 (3.002ms) : audio gap was filled with silence
FFDEC035: [dca @ 000002170cdd6bf0] Warning: not compiled with thread support, using thread emulation
AV sync in 1 at 7:42:32.917 (8.002ms) : audio gap was filled with silence
AV sync in 1 at 8:03:55.197 (9.002ms) : audio gap was filled with silence
FFDEC037: [dca @ 000002170c8d52b0] Warning: not compiled with thread support, using thread emulation
AV sync in 1 at 8:30:49.808 (10.335ms) : audio gap was filled with silence
FFDEC038: [dca @ 000002171f622520] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 37 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 8:48:51.899 (1.002ms) : audio gap was filled with silence
FFDEC039: [dca @ 000002171f622090] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 38 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 9:08:17.062 (1.335ms) : audio gap was filled with silence
FFDEC040: [dca @ 000002171f9364f0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 39 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 9:17:04.584 (7.002ms) : audio gap was filled with silence
FFDEC041: [dca @ 000002171f937730] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 40 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 9:39:11.908 (8.668ms) : audio gap was filled with silence
FFDEC042: [dca @ 000002170c76c950] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 41 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 10:04:27.426 (4.668ms) : audio gap was filled with silence
FFDEC043: [dca @ 000002170c76c4c0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 42 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 10:22:14.492 (4.668ms) : audio gap was filled with silence
FFDEC044: [dca @ 000002170c76c4c0] Warning: not compiled with thread support, using thread emulation
AV sync in 1 at 10:47:01.974 (8.668ms) : audio gap was filled with silence
FFDEC045: [dca @ 000002171dd52610] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 44 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 11:12:17.492 (4.668ms) : audio gap was filled with silence
FFDEC046: [dca @ 000002171dd52f30] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 45 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 11:37:29.998 (9.668ms) : audio gap was filled with silence
FFDEC047: [dca @ 000002171f84c520] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 46 at +GpG]0W#$s;j-fhkL:o:29399381
AV sync in 1 at 12:04:41.634 (3.335ms) : audio gap was filled with silence
Post by Woodstock » Tue Aug 21, 2018 12:43 pm
If you use the "default" or "wdtv" profile, do you still get the thread emulation warnings? I'm suspicious of an issue with converting the audio to FLAC.
ubertrout
Post by ubertrout » Tue Aug 21, 2018 12:56 pm
It works fine on "default," but that mode is not for decoding a BD-Audio disc where the whole point is getting the audio in original resolution FLAC format. At the end it gave a generic "error, will exit" without giving more details.
I tried it again last night after downloading the latest version, this might be more helpful:
Debug log started at Tue Aug 21 04:49:48 2018 , written by MakeMKV v1.12.3 win(x64-release)
001005:0000 MakeMKV v1.12.3 win(x64-release) started
DEBUG: Code 2365587456 at KP2EQg,Ybj})Rn!@:29405660
DEBUG: Code 0 at KP2EQg,Ybj})Rn!@:213139943
DEBUG: Code 0 at ug!Y?M}h37%"DxLT:29400623
DEBUG: Code 2147483648 at KP2EQg,Ybj})Rn!@:213133250
DCE=xehRuHHwsz6VQZy0Z+NJHsfE0rydCd2GsxC12aJFO3iFkces4MnhkD1i65EhHPomAmh2EvrRI32yMRJx4O/1YswR3P+npRdlz2jjJiaTxr+pv70la/4tdmUDyzvLJ/HOYZ7HPV7jZwgyRI0uYG3rJSfRyqXYoqiSAQ==
DCE=59kJ5bFZgozItxwaMNgNcq3e1/P6Fd8l7FrqTYIkgYSw9O5kiveVflLcF4kdpnmOzvIKw/ZS/nqL2/gfg81fv2PGTirhHxFIKe/IHItZf/laXC5YBwgG4ta1dh4eTXaqdW9EbKbHjyOP83nyJf1eeM1s24i+L8Ictg==
FFDEC001: [dca @ 0000021e7bb6ec90] Warning: not compiled with thread support, using thread emulation
FFDEC036: [dca @ 0000021e7bb4b050] Warning: not compiled with thread support, using thread emulation
FFENC048: [flac @ 0000021e7bb6e1e0] Warning: not compiled with thread support, using thread emulation
FFENC048: [flac @ 0000021e7bb6e1e0] compression: 5
FFENC048: [flac @ 0000021e7bb6e1e0] lpc type: Levinson-Durbin recursion with Welch window
FFENC048: [flac @ 0000021e7bb6e1e0] prediction order: 1, 8
FFENC048: [flac @ 0000021e7bb6e1e0] order method: estimate
FFENC048: [flac @ 0000021e7bb6e1e0] partition order: 0, 8
FFENC048: [flac @ 0000021e7bb6e1e0] block size: 16384
FFENC048: [flac @ 0000021e7bb6e1e0] lpc precision: 15
FFDEC002: [dca @ 0000021e7bb6ec90] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 1 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC003: [dca @ 0000021e7bb6ec90] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 2 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC004: [dca @ 0000021e7bb6ec90] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 3 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC005: [dca @ 0000021e7bb6ec90] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 4 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC006: [dca @ 0000021e7bb6ec90] Warning: not compiled with thread support, using thread emulation
FFDEC007: [dca @ 0000021e7bb6ec90] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 6 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC008: [dca @ 0000021e7bb6ec90] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 7 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC009: [dca @ 0000021e7bb6ec90] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 8 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC010: [dca @ 0000021e7bb6ec90] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 9 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC011: [dca @ 0000021e7c2f1280] Warning: not compiled with thread support, using thread emulation
FFDEC012: [dca @ 0000021e7bfe73d0] Warning: not compiled with thread support, using thread emulation
FFDEC013: [dca @ 0000021e7b7aa250] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 12 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC014: [dca @ 0000021e7c040250] Warning: not compiled with thread support, using thread emulation
FFDEC015: [dca @ 0000021e7be9fe20] Warning: not compiled with thread support, using thread emulation
FFDEC016: [dca @ 0000021e7c4410a0] Warning: not compiled with thread support, using thread emulation
FFDEC017: [dca @ 0000021e0e6a34f0] Warning: not compiled with thread support, using thread emulation
FFDEC018: [dca @ 0000021e0e3df1a0] Warning: not compiled with thread support, using thread emulation
FFDEC019: [dca @ 0000021e7bb6e680] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 18 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC020: [dca @ 0000021e7bb6e680] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 19 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC021: [dca @ 0000021e7bb6e680] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 20 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC022: [dca @ 0000021e7c58d1a0] Warning: not compiled with thread support, using thread emulation
FFDEC023: [dca @ 0000021e7c194270] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 22 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC024: [dca @ 0000021e7bb6bb20] Warning: not compiled with thread support, using thread emulation
FFDEC025: [dca @ 0000021e7bb6bb20] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 24 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC026: [dca @ 0000021e7bb6bb20] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 25 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC027: [dca @ 0000021e7c15dcb0] Warning: not compiled with thread support, using thread emulation
FFDEC028: [dca @ 0000021e7bb6bb20] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 27 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC029: [dca @ 0000021e7bb6bb20] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 28 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC030: [dca @ 0000021e7c58d1a0] Warning: not compiled with thread support, using thread emulation
FFDEC031: [dca @ 0000021e7bb6bb20] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 30 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC032: [dca @ 0000021e7c1942c0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 31 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC033: [dca @ 0000021e7bb6bb20] Warning: not compiled with thread support, using thread emulation
FFDEC034: [dca @ 0000021e7bb6bb20] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 33 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC035: [dca @ 0000021e7bb6bb20] Warning: not compiled with thread support, using thread emulation
FFDEC037: [dca @ 0000021e7bb4b050] Warning: not compiled with thread support, using thread emulation
FFDEC038: [dca @ 0000021e7bb4b050] Warning: not compiled with thread support, using thread emulation
FFDEC039: [dca @ 0000021e7bb4b050] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 38 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC040: [dca @ 0000021e7c1942c0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 39 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC041: [dca @ 0000021e7bfb3190] Warning: not compiled with thread support, using thread emulation
FFDEC042: [dca @ 0000021e7c441090] Warning: not compiled with thread support, using thread emulation
FFDEC043: [dca @ 0000021e7bc79df0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 42 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC044: [dca @ 0000021e7bc79df0] Warning: not compiled with thread support, using thread emulation
FFDEC045: [dca @ 0000021e7c13ac80] Warning: not compiled with thread support, using thread emulation
FFDEC046: [dca @ 0000021e7bf220a0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 45 at F%oNaQv#eQ+3)x*al^4:121267638
FFDEC047: [dca @ 0000021e7bf220a0] Warning: not compiled with thread support, using thread emulation
DEBUG: Code 46 at F%oNaQv#eQ+3)x*al^4:121267638
Post by Woodstock » Tue Aug 21, 2018 2:49 pm
This is definitely one Mike will have to look at, since it seems to be in the FLAC encoder.
ubertrout
Post by ubertrout » Tue Aug 21, 2018 10:12 pm
Woodstock wrote: Tue Aug 21, 2018 2:49 pm This is definitely one Mike will have to look at, since it seems to be in the FLAC encoder.
Okay, thanks. This might be the single largest audio track on a blu-ray ever - it's 38GB and the disc has no video content. I also did see that MakeMKV was using some 8GB of memory in at least one point of the process.
ubertrout
Post by ubertrout » Thu Aug 23, 2018 1:40 pm
For whatever it's worth, I eventually got my FLACs - I created a MKV using normal settings, demuxed to FLAC, extracted the chapterlist, remuxed using the FLAC and chapterlist, and then opened the MKA file in foobar and converted to individual FLACs per track. I also realize that this isn't the longest audio track I've converted - Solti Conducts the Ring Cycle of operas by Wagner is 23 hours long, but the audio track was only 24-bit/48khz on that one.
Maybe this is just an isolated problem with this disc?
