So I'm making a backup of my Box collection of Kenshin (Samurai X) cotnaining 12DVD's.
I'm using makemkv to create a mkv of every single disc. Not changing a single setting.
But it always fails close to the end on disc 3 of the collection. All the other discs went fine.
Extra information:
I successfully made an ISO file of all 12 DVD discs. All the iso's are bootable and play fine. Same with DVD/ISO 3, played it in my ps4 nd watched it untill the end. Also the ISO creating was not a problem.
Still makemkv can't successfully create an MKV file. Tried both with the original DISC and the ISO.
Any ideas or other ways to complete my rip?
Kenshin 12 DVD collection. One single disk failing...
vree360
Re: Kenshin 12 DVD collection. One single disk failing...
A debug log (FAQ link in my signature) would be helpful to see what kind of error is being encountered.
vree360
Debug log started at Mon Aug 20 16:43:04 2018 , written by MakeMKV v1.12.3 win(x64-release)Woodstock wrote: Mon Aug 20, 2018 3:12 pm A debug log (FAQ link in my signature) would be helpful to see what kind of error is being encountered.
001005:0000 MakeMKV v1.12.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Dimi/MakeMKV_log.txt
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
003028:0000 Title #1 was added (40 cell(s), 3:10:09)
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003025:0000 Title #2 has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=2 pgcn=1 hash=E8310777DE476563
003019:0000 Cells 3-end were skipped due to cell commands (structure protection?)
003025:0000 Title #2/0/1 has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at 0RYoYFFaMJGPXta3esacRoBM:0
005014:0000 Saving 1 titles into directory I:/Kenshin dvd rips/DVD 3
001002:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
005003:0000 Failed to save title 0 to file I:/Kenshin dvd rips/DVD 3/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Mon Aug 20 16:57:06 2018
vree360
IFO files:
https://wetransfer.com/downloads/efb09d ... 923/3d1afb
DISC LABEL:
GOD3
MakeMKV v1.12.3
If needed I can share the ripped iso version. But again before someone says it. Like I said before I tried MakeMKV on both the ISO and the original DVD with the exact same result at the exact same moment.
I even tried 2 different ISO making tools to verify it isn't just the disk. One that verifies every single sector. And all of them where OK, not a single bad one.
And as stated before whatched all episodes on that disc in my PS4 and that worked fine.
DISC LABEL:
GOD3
MakeMKV v1.12.3
You could try going back to version 1.12.2; there have been some issues with 1.12.3 on SOME disks.
vree360
Woodstock wrote: Mon Aug 20, 2018 8:29 pm You could try going back to version 1.12.2; there have been some issues with 1.12.3 on SOME disks.
Where can I download these old versions?
vree360
Can't use the older version needs a registration code...
vree360
EDIT: Nope still no luck using that version. Will have to take do with HandBrake for now for that one disk.vree360 wrote: Tue Aug 21, 2018 6:45 pmCan't use the older version needs a registration code...
EDIT: Never mind found the key. Testing now.
