Dead Pool
charlie62
Dead Pool
Is there such a thing as a copy (uk) deadpool that works without a fatal error around around 12 gb 000163mts is corrupt maybe 5 files. This is the 3rd disc with the same error. Does this mean that it makes no difference what I do to clean it nothing will work let me know Thanks
charlie62
Re: Dead Pool
SOLVED ! I used jonghotti's method of immersing the disc in a bowl of hot water(not boiling) with washing up liquid and top up occasionally with hot water and viola it worked with no problem. I gave it nearly an hour before drying and trying.
