Application failed to initialize - Sierra 10.12.6 (16G1510)
ziggyspider
Re: Application failed to initialize - Sierra 10.12.6 (16G1510)
Without more information, even wild-ass guesses are hard to come by.
What does the system log say about the failure?
ziggyspider
thanks, how can I get the .log, where???
I just open the app and crash and show me that message.
please let me know where log is stored and I post it here.
ziggyspider
I found this:
Aug 16 16:00:11 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[6526]): Service exited with abnormal code: 1
helps?
helps?
ziggyspider
I think I found the log:
Aug 16 00:18:24 John-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000000b.makemkv[19909]): Service exited with abnormal code: 1
Aug 16 00:20:11 John-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000000a.makemkv[19887]): Service exited with abnormal code: 1
Aug 16 00:20:35 John-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000000d.makemkv[20010]): Service exited with abnormal code: 1
Aug 16 00:24:22 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[20162]): Service exited with abnormal code: 1
Aug 16 00:26:50 John-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000000f.makemkv[20259]): Service exited with abnormal code: 1
Aug 16 00:32:27 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[20290]): Service exited with abnormal code: 1
Aug 16 15:58:07 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[6465]): Service exited with abnormal code: 1
Aug 16 16:00:39 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[6537]): Service exited with abnormal code: 1
Aug 16 19:07:18 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[11070]): Service exited with abnormal code: 1
Aug 16 19:08:00 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[11085]): Service exited with abnormal code: 1
spl147
if i remember correctly, MakeMKV is now 64bit only, try updating your OS, as you are way behind!ziggyspider wrote: Fri Aug 17, 2018 1:09 am I think I found the log:
Aug 16 00:18:24 John-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000000b.makemkv[19909]): Service exited with abnormal code: 1 Aug 16 00:20:11 John-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000000a.makemkv[19887]): Service exited with abnormal code: 1 Aug 16 00:20:35 John-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000000d.makemkv[20010]): Service exited with abnormal code: 1 Aug 16 00:24:22 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[20162]): Service exited with abnormal code: 1 Aug 16 00:26:50 John-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000000f.makemkv[20259]): Service exited with abnormal code: 1 Aug 16 00:32:27 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[20290]): Service exited with abnormal code: 1 Aug 16 15:58:07 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[6465]): Service exited with abnormal code: 1 Aug 16 16:00:11 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[6526]): Service exited with abnormal code: 1 Aug 16 16:00:39 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[6537]): Service exited with abnormal code: 1 Aug 16 19:07:18 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[11070]): Service exited with abnormal code: 1 Aug 16 19:08:00 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[11085]): Service exited with abnormal code: 1
Yes, from the download page:
MakeMKV 1.12.3 for Mac OS X
* Requires x64 Mac OS X 10.6 or later.
Lovely Rita
How is 10.12.6 (Sierra) behind Snow Leopard 10.6.
Besides the 32- vs. 64-bit issue? I'm certainly not a MacOS expert, but 32-bit versions won't run 64-bit software, and MakeMKV is 64-bit only now.
(of course, some people will argue endlessly about how their favorite software package was broken when they update to whatever the next version of the operating system is, making the new one "behinder" than the old one.)
Lovely Rita
If they're truly on 10.12.6 then it would not be the OS because I'm on 10.12.6 also.
For my purposes it runs like a champ!
ziggyspider
I don't get it... yes I'm on Sierra, so this not runs on Sierra???
The requirements says clearly, 10.6 and up, I'm on 10.12
confused...
confused...
Lovely Rita
If I was having this issue, I would uninstall the app, reboot and then reinstall.
I use App Cleaner to uninstall unwanted or troublesome apps.
http://freemacsoft.net/appcleaner/
Also, did you download your copy of MakeMKV from this site?
ziggyspider
hi, yes I already delete the app with App Cleaner, and restart and same thing,
even I start the mac with in safe mode...
nothing works
I think I need erase the system and install high sierra and cross my fingers to see if works.
thanks
nothing works
thanks
ziggyspider
This app never works on Sierra!
jackyardfilament
Thanks for the link.Lovely Rita wrote: Fri Aug 17, 2018 10:27 pm If I was having this issue, I would uninstall the app, reboot and then reinstall.
