I apologize if this is an often-asked-and-answered question but I haven't been able to find the answer by searching in the forums here.
Is there any way with MakeMKV to produce an unencrypted backup of a DVD (i.e. the VIDEO_TS folder), as there is with Blu-ray? The FAQ mentions only how to create an M2TS backup from a Blu-ray, and that works quite well, but sure enough the "backup" option doesn't appear at all when ripping a DVD.
And if there indeed isn't any way to do this with MakeMKV, what other software would be suitable for this (in particular on a Mac)?
VIDEO_TS DVD backup
polymath
Re: VIDEO_TS DVD backup
Okay, more thorough searching uncovered several threads that do indeed talk about this, and confirmed that there is currently no support for this in MakeMKV. So I'll add my vote for including this feature in a future release.
I'd still welcome recommendations on how to do this easily in MacOS. In the past I've used AnyDVD in a Windows Virtual Machine, and I could still do this, but it's troublesome. A modern native solution would be preferable.
I've also installed "dvdbackup" via MacPorts and tried that but haven't been able to get it to work (complains that it "Cannot seek DVD device").
Thanks.
Thanks.
The "backup" feature for Bluray was added because there was no equivalent of it elsewhere.
For DVD, there have been utilities, both free and otherwise, that can make an ISO, which is then playable in many devices... The CSS encryption used on DVDs is well understood and decryption of DVDs is built into many software players, so it isn't even necessary to decrypt the ISO.
On Linux and Mac, you can use the utility 'dd' to create a DVD ISO that is playable.
One such utility that I've used in the past on Windows is called "bdlot". But there has been no need to update it in so long that the developers lost interest in it, and you can only find it on archive sites now.
xr200
I use dvdbackup (on Linux) frequently, never had any problem.I've also installed "dvdbackup" via MacPorts and tried that but haven't been able to get it to work (complains that it "Cannot seek DVD device").
My command line is usually this:
dvdbackup -i /dev/sr0 -p -M -o /tmp -n "title_of_the_dvd"-
polymath
The device name was correct (/dev/disk25 in this case) but I wasn't supplying the "-n" option (didn't think it was needed for a full-disc rip).xr200 wrote: Sat Aug 18, 2018 8:05 pmI use dvdbackup (on Linux) frequently, never had any problem.
Are you sure you are identifying your dvd device correctly?Code: Select all
With "-n" it works fine. Thanks very much.
xr200
It depends on the DVD. Sometimes dvdbackup isn't able to auto-detect the title for you.I wasn't supplying the "-n" option (didn't think it was needed for a full-disc rip).
No clue as to why that is. I just always use the "-n" option to avoid any problem.
