Hashed Key Thread Updateing Notifications?
spl147
Post by spl147 »
how can we be notified when the hashed key file is updated, since mike is only editing the original post, subscription notifications are not sent.
onienzeru
Re: Hashed Key Thread Updateing Notifications?
Post by onienzeru »
^-- This would be awesome
Lovely Rita
Post by Lovely Rita »
No notifications exist in phpBB, by default, for post edits.
This applies to both the user and Admin control panel.
Registered User :wink:
Buy MakeMKV
st4evr
Post by st4evr »
Additionally, Mike has already mentioned that eventually he would like to have an automatic key/file update occur through the app. So, it’s most likely that is what he will pursue in his development.
bmillham
Post by bmillham »
Or at least use a URL that does not change every time you access it so I could do something like setup a cron job that updates the file daily.
danBoi2016
Post by danBoi2016 »
what about a database for 4k hashed keys the same used for normal blurays and dvds
Krawk
Post by Krawk »
danBoi2016 wrote:what about a database for 4k hashed keys the same used for normal blurays and dvds
Honestly, worst case scenario, this site or the servers get shut down, if you have the hashed key file locally, you can always decrypt them.
Much like I would like to maintain a copy locally of all BD patches, but I suspect that would get rather large.
archer
Post by archer »
bmillham wrote:Or at least use a URL that does not change every time you access it so I could do something like setup a cron job that updates the file daily.
I wrote a small app to do just that (all you need is nodejs (https://nodejs.org/en/download/) installed on windows, osx or linux). And when you run the app, it checks the date in the pinned forum post, if it's a newer date it, it opens the URL and downloads the new keys. I have it running as a cronjob and a windows task.
I'll share it if anyone is interested.
spl147
Post by spl147 »
archer wrote: Sat Aug 11, 2018 3:31 pm
please
garretn
Post by garretn »
If you just want a cron job I use this small bash script to do just that:
#!/bin/bash -x
URL1=$(curl --silent 'https://www.makemkv.com/forum/app.php/feed/topic/16959' | grep tinyupload | sed 's/ /\n/g' | grep '^href.*tinyupload' | sed 's/href="//;s/"//')
URL2=$(curl --silent -c cookies.txt "$URL1" | grep download.php | sed 's/.*download.php/download.php/;s/".*//')
curl --silent -c cookies.txt "http://s000.tinyupload.com/$URL2" | tee hash_keys.txt.new | grep -q VAN_HELSING && mv hash_keys.txt.new ~/.MakeMKV/keys_hashed.txt || (rm -f hash_keys.txt.new && echo failed)
Post by SamuriHL »
Nice script. Just ran it under WSL and works great. Wish I had thought of that. LOL Thanks for sharing.
gonca
Post by gonca »
Script might not be needed with newest version
DEBUG: Code 03DF
Downloading latest HK to C:/Program Files (Portable)/KEYS ...
bmillham
Post by bmillham »
garretn wrote: Wed Aug 15, 2018 2:31 pm If you just want a cron job I use this small bash script to do just that:
#!/bin/bash -x
Thank you for this, tested and working on Mint 19 :D
spl147
Post by spl147 »
#!/bin/bash -x
works perfect with a minor change for user scripts on unRAID
