Application failed to initialize - Sierra 10.12.6 (16G1510)
ziggyspider
Post by ziggyspider » Thu Aug 16, 2018 6:32 am
screenshot https://cl.ly/3e2e2o3e1u39
any help, please!!!!
Re: Application failed to initialize - Sierra 10.12.6 (16G1510)
Post by Woodstock » Thu Aug 16, 2018 1:28 pm
Without more information, even wild-ass guesses are hard to come by.
What does the system log say about the failure?
ziggyspider
Post by ziggyspider » Thu Aug 16, 2018 9:59 pm
thanks, how can I get the .log, where???
I just open the app and crash and show me that message.
please let me know where log is stored and I post it here.
ziggyspider
Post by ziggyspider » Thu Aug 16, 2018 10:02 pm
I found this:
Aug 16 16:00:11 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[6526]): Service exited with abnormal code: 1
helps?
ziggyspider
Post by ziggyspider » Fri Aug 17, 2018 1:09 am
I think I found the log:
Aug 16 00:18:24 John-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000000b.makemkv[19909]): Service exited with abnormal code: 1
Aug 16 00:20:11 John-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000000a.makemkv[19887]): Service exited with abnormal code: 1
Aug 16 00:20:35 John-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000000d.makemkv[20010]): Service exited with abnormal code: 1
Aug 16 00:24:22 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[20162]): Service exited with abnormal code: 1
Aug 16 00:26:50 John-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.oneshot.0x1000000f.makemkv[20259]): Service exited with abnormal code: 1
Aug 16 00:32:27 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[20290]): Service exited with abnormal code: 1
Aug 16 15:58:07 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[6465]): Service exited with abnormal code: 1
Aug 16 16:00:39 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[6537]): Service exited with abnormal code: 1
Aug 16 19:07:18 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[11070]): Service exited with abnormal code: 1
Aug 16 19:08:00 John-MacBook-Pro com.apple.xpc.launchd[1] (com.makemkv.MakeMKV.80624[11085]): Service exited with abnormal code: 1
spl147
Post by spl147 » Fri Aug 17, 2018 1:35 pm
ziggyspider wrote: Fri Aug 17, 2018 1:09 am I think I found the log:
if i remember correctly, MakeMKV is now 64bit only, try updating your OS, as you are way behind!
Post by Woodstock » Fri Aug 17, 2018 2:37 pm
Yes, from the download page:
MakeMKV 1.12.3 for Mac OS X
* Requires x64 Mac OS X 10.6 or later.
Lovely Rita
Post by Lovely Rita » Fri Aug 17, 2018 4:39 pm
How is 10.12.6 (Sierra) behind Snow Leopard 10.6. :?
Registered User :wink:
Buy MakeMKV
Post by Woodstock » Fri Aug 17, 2018 5:20 pm
Besides the 32- vs. 64-bit issue? I'm certainly not a MacOS expert, but 32-bit versions won't run 64-bit software, and MakeMKV is 64-bit only now.
(of course, some people will argue endlessly about how their favorite software package was broken when they update to whatever the next version of the operating system is, making the new one "behinder" than the old one.)
Lovely Rita
Post by Lovely Rita » Fri Aug 17, 2018 5:30 pm
If they're truly on 10.12.6 then it would not be the OS because I'm on 10.12.6 also.
For my purposes it runs like a champ!
Buy MakeMKV
ziggyspider
Post by ziggyspider » Fri Aug 17, 2018 7:05 pm
I don't get it... yes I'm on Sierra, so this not runs on Sierra???
The requirements says clearly, 10.6 and up, I'm on 10.12 :roll:
confused...
Lovely Rita
Post by Lovely Rita » Fri Aug 17, 2018 10:27 pm
If I was having this issue, I would uninstall the app, reboot and then reinstall.
I use App Cleaner to uninstall unwanted or troublesome apps.
http://freemacsoft.net/appcleaner/
Also, did you download your copy of MakeMKV from this site?
Buy MakeMKV
ziggyspider
Post by ziggyspider » Sun Aug 19, 2018 8:20 am
hi, yes I already delete the app with App Cleaner, and restart and same thing,
even I start the mac with in safe mode...
nothing works
:( I think I need erase the system and install high sierra and cross my fingers to see if works.
thanks
ziggyspider
Post by ziggyspider » Thu Aug 30, 2018 3:52 am
This app never works on Sierra! :(
jackyardfilament
Post by jackyardfilament » Mon Oct 08, 2018 5:51 am
Lovely Rita wrote: Fri Aug 17, 2018 10:27 pm If I was having this issue, I would uninstall the app, reboot and then reinstall.
Thanks for the link.
