John Wick UK Blu Ray, Rip timing problem
Cigar
#1 Post by Cigar » Sun Aug 12, 2018 6:19 am
Hi guys,
I've just found a strange problem with John Wick Blu ray, UK version.
I'm talking about the first movie, John Wick 2014 not John Wick 2.
The problem is that when you rip this movie using MakeMKV, I'm on the very latest version, you find that there's some blank space at the end of the rip...
It is very strange as this doesn't usually happen. According to MakeMKV there is only 1 segment for the movie. It's nothing like the US one where there is multiple segments...
The movie is supposed to be about 1:41:12 or something around there but MakeMKV seems to rip it at around 1:42:00. It seems to hang on for ages in VLC player. I've also checked by playing in Android and it reads it all the way until about 1:41:46 then cuts out but yet just plays Blank screen for a while. That Blank playing bit shouldn't be there really it should just finish at about 1:41:12. I can't seem to do anything about this which is why it's so strange so does anybody have any suggestions on something that might be possible to get it down to 1:41:12 like it should be. If anybody has the UK disc then give it a try and see if you are having the exact same problem as me...
Many thanks
(P.S. My John Wick disc is from the double pack boxset)
Re: John Wick UK Blu Ray, Rip timing problem
#2 Post by Woodstock » Sun Aug 12, 2018 8:04 am
John Wick (both movies) uses playlist obfuscation. Which play list did you rip?
Cigar
#3 Post by Cigar » Sun Aug 12, 2018 3:06 pm
Woodstock wrote: Sun Aug 12, 2018 8:04 am John Wick (both movies) uses playlist obfuscation. Which play list did you rip?
The only playlist.
Cigar
#4 Post by Cigar » Sun Aug 12, 2018 3:13 pm
Cigar wrote: Sun Aug 12, 2018 3:06 pm
The only playlist.
Playlist obfuscation on the UK disc, guess again there is no playlist obfuscation on this disc...
Cigar
#5 Post by Cigar » Sun Aug 12, 2018 3:41 pm
Cigar
#6 Post by Cigar » Sun Aug 12, 2018 4:00 pm
Full log:
MakeMKV v1.12.3 win(x64-release) started
File 00554.mpls was added as title #0
File 00001.mpls was added as title #1
Title #00552.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00557.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00106.m2ts was added as title #2
File 00105.m2ts was added as title #3
Title #00998.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00104.m2ts was added as title #4
File 00103.m2ts was added as title #5
File 00102.m2ts was added as title #6
Title #00021.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/[Blu Ray Rip]/2014 - John Wick
1 titles saved
