Star Trek TOS Blu-ray collection 2016 version - Failed to save title 0 to file V:/Video/Star_Trek_Season_1_Disc_5/Star_Trek_Season_1_Disc_5_t00.mkv
This has occurred on every disc I have tried so far, I have cleaned the discs and tested my drive by ripping prior known good content. Right now it appears to only be these discs. Discs have no visible damage.
What should I try?
MakeMKV v1.12.3 win(x64-release) started
DEBUG: Code 0 at NZY_\d3mS{)ta%8H:121262325
File 00000.mpls (angle 1) was added as title #0
File 00000.mpls (angle 2) was added as title #1
File 00001.mpls (angle 1) was added as title #2
File 00001.mpls (angle 2) was added as title #3
File 00002.mpls (angle 1) was added as title #4
File 00002.mpls (angle 2) was added as title #5
File 00003.mpls (angle 1) was added as title #6
File 00003.mpls (angle 2) was added as title #7
Title #00009.mpls has length of 127 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00017.mpls has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00018.mpls has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00019.mpls has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00016.mpls has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00160.m2ts has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00161.m2ts has length of 62 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00162.m2ts has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00163.m2ts has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00165.m2ts has length of 67 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00166.m2ts has length of 60 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00169.m2ts has length of 17 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00173.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00175.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00180.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00184.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00186.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00190.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00170.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00171.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
File 00147.m2ts was added as title #8
File 00148.m2ts was added as title #9
Title #00149.m2ts has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Saving 6 titles into directory V:/Video/Star_Trek_Season_1_Disc_5
DEBUG: Code 45045000 at n]b0~$o-o?V5vbG:khR:121265821
DEBUG: Code 0 at 7(:bJRPje>S[z:y!Z~".~:121267661
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 2 to file G:/Video/Star_Trek_Season_1_Disc_5/Star_Trek_Season_1_Disc_5_t02.mkv
Star Trek TOS blu-ray errors - Failed to save title
anson.maddock
anson.maddock
Re: Star Trek TOS blu-ray errors - Failed to save title
Reading thru problems others were experiencing with discs I decided to downgraded from 1.12.3 to 1.12.2.
The problem stopped occurring. I don't know what this means exactly, either 1.12.3 was detecting errors and throwing alerts or 1.12.3 has an issue.
I am willing to run tests, take dumps, send extracts as needed.
hoba_rce
Same here.
Tried to do a backup of my TOS Bluray collection to my NAS so that i do not have to jiggle 200 discs all the time and risk breaking them while removing from the most stupid disc box i ever seen.
Ended up with the same error as OP. Tried on 2 different machines. Even tried to rip it from the bluray .iso image created by other software. No luck. Solution is to remove subtitles from the selection or use older version 1.12.2 that works fine. Or use DVDFab that also works fine with the set.
BTW, my Star Trek TNG bluray set was backed up just fine.
Two more thing that i find extremely annoying with Star Trek ripping:
1) The sets contains DTS-MA 7.1 sound track but it is not selected by default. You have to manually click it every time, as only legacy DTS 5.1 track is selected from the start. That is extremely annoying, given the fact, that DTS-MA is backward compatible with DTS. Any reciever that can play old DTS can also play DTS-MA as it will only take the legacy DTS core from it. For comparison - DVDFab will select the DTS-MA track as default when in .mkv passtrough mode....
2) When multiple sound tracks with the same language are detected, only one is selected by default. That is typically the Directors commentary track that is in English and you have to select it manually every time as the software thinks that there is already another english (original audio) track....
But compliments to the author - MakeMKV is a solid piece of software that i will probably buy when it is out of beta if the price will be right...
By selecting 'Expert mode' on the 'General' preferences tab, you can modify your default selection rule with switches detailed here:hoba_rce wrote:Two more thing that i find extremely annoying with Star Trek ripping:
1) The sets contains DTS-MA 7.1 sound track but it is not selected by default. You have to manually click it every time, as only ordinary DTS 5.1 track is selected from the start. That is extremely annoying, given the fact, that DTS-MA is backward compatible with DTS. Any reciever that can play old DTS can also play DTS-MA as it will only take the old DTS core from it. For comparison - DVDFab will select the DTS-MA track as default when in .mkv passtrough mode....
http://www.makemkv.com/forum2/viewtopic ... 386#p17399
You MAY need to tweak this to your prefs, but I use:
-sel:all,+sel:audio&(eng),-sel:mvcvideo,+sel:subtitle&(eng),=100:all,-10:eng
in the 'Advanced' tab to select all english tracks by default. Give it a try.
hoba_rce
Thank you for the tip. Tried this:d00zah wrote:Give it a try.
+sel:all, -sel:core
Now it selects all the tracks except the DTS legacy core, that is already included in the DTS-MA, but would rip into separate 2nd DTS track if selected, occupying another 1GB per episode....
As for the video - all tracks are doubled - one with original 1960´s visual effects, one with remastered 2010´s effects, listed as "angle 1" and "angle 2".
Only one angle is selected by default despite the "+sel:all". Did not find a switch to select both. Tried "+sel:mvcvideo" but no luck....
Pretty sure they are being interpreted as duplicate titles. Right-click on any title (or is it the top level? Try both) & choose 'Select all'.
For audio selection, try 'havecore'.
hoba_rce
Thanks, now works as i need...except the OP´s original problemd00zah wrote: choose 'Select all'.
For that, I got nuthin'... except for downgrading to v1.12.2, that is.
Callindril
Getting the same kind of wacky error messages trying to rip these ST:TOS disks...
Went back to the aforementioned 1.12.2 after getting the same issues as the OP on 1.12.3, but instead of working fine, I got this message over and over...
Never had an issue with this great program before...wonder what's going on with these ST disks...
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '285081600'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '285081600'
DEBUG: Code 3221225492 at ,i4-.2g.]3n$zk0ZB=:121262969
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '285081600'
DEBUG: Code 3221225488 at ,i4-.2g.]3n$zk0ZB=:121262969
Callindril
For what it's worth, I went back to 1.10.10, still get the same messages...
Saving 1 titles into directory G:/Capture/Blurays
DEBUG: Code 0 at rR5wo2R>;&04p%S":121262325
AV synchronization issues were found in file 'G:/Capture/Blurays/Star_Trek_Season_1_Disc_1_t00.mkv' (title #1)
AV sync issue in stream 1 at 0:00:27.152 with duration of 5.208ms : encountered overlapping frame, audio skew is +5.208ms
AV sync issue in stream 1 at 0:02:27.355 with duration of 9.916ms : encountered overlapping frame, audio skew is +15.125ms
AV sync issue in stream 1 at 0:02:27.370 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +4.458ms
AV sync issue in stream 1 at 0:03:24.621 with duration of 3.791ms : encountered overlapping frame, audio skew is +8.25ms
AV sync issue in stream 1 at 0:04:05.119 with duration of 2.541ms : encountered overlapping frame, audio skew is +10.791ms
AV sync issue in stream 1 at 0:04:05.130 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.125ms
AV sync issue in stream 1 at 0:04:33.231 with duration of 5.916ms : encountered overlapping frame, audio skew is +6.041ms
AV sync issue in stream 1 at 0:07:54.182 with duration of 9.25ms : encountered overlapping frame, audio skew is +15.291ms
AV sync issue in stream 1 at 0:07:54.197 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +4.625ms
AV sync issue in stream 1 at 0:10:22.663 with duration of 9ms : encountered overlapping frame, audio skew is +13.625ms
AV sync issue in stream 1 at 0:10:22.677 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.958ms
AV sync issue in stream 1 at 0:11:21.055 with duration of 8.333ms : encountered overlapping frame, audio skew is +11.291ms
AV sync issue in stream 1 at 0:11:21.066 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.625ms
AV sync issue in stream 1 at 0:11:32.858 with duration of 4.541ms : encountered overlapping frame, audio skew is +5.166ms
AV sync issue in stream 1 at 0:26:38.847 with duration of 6.25ms : encountered overlapping frame, audio skew is +11.416ms
AV sync issue in stream 1 at 0:26:38.858 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.75ms
AV sync issue in stream 1 at 0:27:00.118 with duration of 8.75ms : encountered overlapping frame, audio skew is +9.5ms
AV sync issue in stream 1 at 0:29:52.415 with duration of 1.541ms : encountered overlapping frame, audio skew is +11.041ms
AV sync issue in stream 1 at 0:29:52.426 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.375ms
AV sync issue in stream 1 at 0:30:25.740 with duration of 8.375ms : encountered overlapping frame, audio skew is +8.75ms
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '287834112'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '287834112'
DEBUG: Code 3221225492 at <!b*q}O_rKz>H_og#c:121262969
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '287834112'
DEBUG: Code 3221225488 at <!b*q}O_rKz>H_og#c:121262969
DEBUG: Code 100806658 at <!b*q}O_rKz>H_og#c:121262969
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '287834112'
DEBUG: Code 101016576 at <!b*q}O_rKz>H_og#c:121262969
DEBUG: Code 0 at ea=uM]h^6`cRU[Qv b%?:29395034
DEBUG: Code 0 at ;EA:*F2K6iX9BEETdzP':29394045
DEBUG: Code 0 at ea=uM]h^6`cRU[Qv b%?:121262647
DEBUG: Code 140544 at ea=uM]h^6`cRU[Qv b%?:213129593
DEBUG: Code 0 at hP$^MMa0>idfSa2WoWs-V:29399197
DEBUG: Code 0 at lC,)'u_hm]<_MPXQw[.:29396782
DEBUG: Code 1 at lC,)'u_hm]<_MPXQw[.:213139414
DEBUG: Code 0 at lC,)'u_hm]<_MPXQw[.:121266856
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '288030720'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '288030720'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '288030720'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '288227328'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '288227328'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '288227328'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '288485376'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '288485376'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '288485376'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '288485376'
DEBUG: Code 140862 at ea=uM]h^6`cRU[Qv b%?:213129593
DEBUG: Code 0 at vSrYO&FgYGWu>G~Tp:213132675
DEBUG: Code 0 at vSrYO&FgYGWu>G~Tp:213132123
DEBUG: Code 0 at vSrYO&FgYGWu>G~Tp:121261980
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 0 to file G:/Capture/Blurays/Star_Trek_Season_1_Disc_1_t00.mkv
Encountered 41 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Is this your only 'problem' disc? The entire set? Any others?
'The disk in drive hs is not formatted properly' sounds like an authoring issue, & my gut says 'bootleg'... or a new protection?
Callindril
I have tried 3 so far, all give the same kind of errors, and they better not be bootleg...Bought them from Amazon on Prime Day...d00zah wrote:Is this your only 'problem' disc? The entire set? Any others?
Wonder if I should send the whole set back and get replacements....
Discs other than those in the set having problems, too? I'd rule that out 1st.
Callindril
I've ripped dozens of disks before this with nary a problem...d00zah wrote:Discs other than those in the set having problems, too? I'd rule that out 1st.
After the first 3 from the set had the issue, the next 3 so far have ripped with no problems...
Looks like the first 3 disks are bad...hopefully none of the others have any issues...
Now I have to figure out how to get replacements for the bad ones....
Cal
anson.maddock
I didn't rip angle 2(original video), I figured I was ok with the special effects, I didn't see any complaints from other fans about the new effects causing changes to the story. I watched one episode, what I saw was mainly the warp core, phasers and other light effects.
Before I discovered that rolling back to 1.12.2 fix the problem I requested a replacement from amazon.
The original shipment was just the plastic box in shrink wrap and many of the discs were loose and the trays didn't have clips for all the discs, so 5 were loose.
The replacement pack with the same copyright dates came with the thin cardboard sleeve around the plastic box and the trays all had clips.
Examining the discs on the first box I saw areas where the plastic wasn't flat and had bubbled and some areas where the metal film on the disc was not even. I should have taken photos. The replacement box sets read fine but I was getting spin up/down on some of the original set. I don't hear my reader kick down into 0.6x often. Either terrible quality control or they were repackaged rejects. Didn't realize the quality difference between the replacement and the original until I had them in hand.
I've been burned by buying on sales before, now I don't order ahead of when I plan to rip. I made a big order one black friday and didn't find out some of my discs were bad until well after the fact. Even budgeting for buying replacements I was ahead but if there was one more disc bad in another season it would have erased all the savings.
