1.12.3 streaming bug
#1 Post by Billycar11 » Mon Jul 30, 2018 5:14 am
i know if says it is soon to be removed but upnp streaming it is now broken might be intentional but when ever i start stream it ends right after i hit ok to the message about it going away.
anyway i guess my real question is when this is gone how will we be able to play disks without backing them up first when this is gone.
tgbauer
Re: 1.12.3 streaming bug
#2 Post by tgbauer » Sat Aug 04, 2018 6:48 am
Noticed the same. Have switched back to prior version as this is the main way I use the App - to be able to play disks on iPad via VLC.
Any way to convince to keep the steaming feature?
#3 Post by Billycar11 » Sat Aug 04, 2018 8:30 am
yeah i also went back to 1.12.2 the only thing i could see replacing this that would be better in some ways worse in others is if after opening the disk it would just create a virtual drive with the unencrypted disk that would work well but then you lost the networking function but could get the menus working in vlc
