Holy Grail main title won't convert
Rmcgrath
Post by Rmcgrath »
I have tried ripping the Holy Grail DVD directly with MakeMKV and also ripping it to an iso file and then converting it with MakeMKV. Either way it doesn't convert the main title just a secondary one. The iso file is +5 GB but the mkv that comes from it is 85 kb...
What can I do to convert the main title?
Re: Holy Grail main title won't convert
It would help to see the debug log from the rip. I ripped MPatHG 5 years ago with no issue, but it was a 2-disk set.
Rmcgrath
Post by Rmcgrath »
The log from when I attempted to rip it directly in MakeMKV or from when I ripped it to an iso?
Rmcgrath
Post by Rmcgrath »
Where would I find logs for MakeMKV?
If you have debug logging turned on (the FAQ in my signature explains how and why), MakeMKV will tell you exactly where the log is being created as it starts up. It will be in the first few lines you see in the activity window at the bottom.
The log is overwritten each time you start, so you could do both in one session, and the log will contain both.
