Failed to save title for Trinity Blood.
Mauron
Post by Mauron »
Trying to rip the first Trinity Blood disk, I got this error. What can I do about it?
MakeMKV v1.12.0 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Brian/MakeMKV_log.txt
Title #1 has length of 22 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #3 was added (1 cell(s), 0:01:01)
Cells 44-end were skipped due to cell commands (structure protection?)
Title #11 was added (43 cell(s), 2:22:09)
Saving 1 titles into directory G:/Video/TRINITY_BLOOD_BOXSET_D1
DEBUG: Code 0 at e=iR<*n*;<hX_0X9):121262026
DEBUG: Code 43 at %O4Z|CSU^#q[yB*pk_:29399979
DEBUG: Code 1793 at %O4Z|CSU^#q[yB*pk_:213136424
DEBUG: Code 518726272 at %O4Z|CSU^#q[yB*pk_:121268236
DEBUG: Code 2148 at %O4Z|CSU^#q[yB*pk_:121268259
DEBUG: Code 4056048192 at %O4Z|CSU^#q[yB*pk_:29400071
AV synchronization issues were found in file 'G:/Video/TRINITY_BLOOD_BOXSET_D1/title01.mkv' (title #2)
AV sync issue in stream 1 at 0:23:45.952 with duration of 72.6ms : audio gap - 2.268 missing frame(s)
AV sync issue in stream 1 at 0:47:31.976 with duration of 72.6ms : audio gap - 2.268 missing frame(s)
AV sync issue in stream 1 at 1:11:18.001 with duration of 72.6ms : audio gap - 2.268 missing frame(s)
AV sync issue in stream 1 at 1:35:04.025 with duration of 72.6ms : audio gap - 2.268 missing frame(s)
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 1 to file G:/Video/TRINITY_BLOOD_BOXSET_D1/title01.mkv
0 titles saved, 1 failed
Nazgvl
Re: Failed to save title for Trinity Blood.
Post by Nazgvl »
Im getting the same error, any work around for this?
This set hasn't changed since I bought and ripped it in 2014, so the error is probably down to the individual disk, or maybe something in MakeMKV.
The version in the original post (1.12.0) in February was replaced due to a bug, and some of us are suspicious that 1.12.3 introduced a navigation bug or two.
What version did you use to attempt to rip this disk, Nazgvl? Was the debug EXACTLY as shown in the parent message?
Nazgvl
Post by Nazgvl »
Im using 1.12.2, and yeah it was pretty much the same message
Saving 1 titles into directory E:/Video/mkv output
AV synchronization issues were found in file 'E:/Video/mkv output/title00.mkv' (title #1)
Failed to save title 0 to file E:/Video/mkv output/title00.mkv
AV sync messages aren't killers, they're informational in nature. Commonly find them when titles are constructed out of multiple video segments.
Make sure debug logging is turned on, and try it again; Nothing in the segment you posted says WHY the save failed. It could be "out of space on destination", a read error, or something not being interpreted correctly.
Nazgvl
Post by Nazgvl »
Yeah, the disc in question (disk 1) has all 6 episodes as one file, with no other options in makemkv.
Turned on debug, and updated to 1.12.3, hoping that might make a difference, and nope.
Here is the error text with debug on. Its pretty much the exact error the OP had.
DEBUG: Code 0 at [9CTUcW}lT(|/'*^W:121262026
DEBUG: Code 43 at W9aA-J[o$f3zN?GxD':121267960
DEBUG: Code 1793 at W9aA-J[o$f3zN?GxD':121267983
DEBUG: Code 518726272 at W9aA-J[o$f3zN?GxD':29399795
DEBUG: Code 2148 at W9aA-J[o$f3zN?GxD':29399634
DEBUG: Code 4056048192 at W9aA-J[o$f3zN?GxD':213135987
Nazgvl
Post by Nazgvl »
So... anyone? Bueller?
Without going through a lot of boxes to find my set, we're going to have to wait for Mike to check in and convert the debug code into something useful. Given the time of month (waiting on a new beta key) it should be soon, but you could send an email to support@makemkv.com with a link to this topic, to get his attention sooner.
Nazgvl
Post by Nazgvl »
So I emailed Mike/support and he had wanted me to do a testdump. Did that and sent him a link as requested but I havent heard anything since. Its been a few weeks now, so I figure id post here again.
So yeah...
Nazgvl
Post by Nazgvl »
*crickets*
TomOrr0W
Post by TomOrr0W »
In case anyone else has issues with this disk in the future:
I had the same issue and was able to work around it. I used manual mode (viewtopic.php?f=1&t=21962&p=89032#p88360) to cut off the last cell from the title. The title selection string was "11:@1-@42". The only content that appears to be lost in doing so is Funimation's DVD credits card.
