I'm using an LG BH12LS38 Blu-Ray drive connected via a Anker USB 3.0 to SATA Portable Adapter and I'm getrting the following across all of my blu-rays but no issues with regular DVD's.
MakeMKV v1.12.3 win(x64-release) started
Evaluation version, 24 day(s) out of 30 remaining
Error 'Scsi error - ILLEGAL REQUEST:SYSTEM RESOURCE FAILURE' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:\Users\Fury/.MakeMKV/MKB_v46_MARVEL'S_CAPTAIN_AMERICA_THE_WINTER_SOLDIER_-_BLU-RAY_561E.tgz
Any suggestions?
Thank you.
Error Ripping Blu-Rays
Re: Error Ripping Blu-Rays
The most common cause of this (other than a real revocation) is that MakeMKV was not able to read the part of the BD that contains key information. Are you running MakeMKV with administrator privileges?
gamingguy5000
Yes, I am.Woodstock wrote:The most common cause of this (other than a real revocation) is that MakeMKV was not able to read the part of the BD that contains key information. Are you running MakeMKV with administrator privileges?
gamingguy5000
No other ideas?
BlueMac77
Hi. Maybe you can try the options below and hope they fixed the problem.gamingguy5000 wrote:No other ideas?
• Try a different older version of MakeMKV
• If you can borrow a different optical drive or different computer to check
• Clean the blu-ray disc
I encountered this same problem once, I reverted to an older version of MakeMKV and this solved the problem.
gamingguy5000
So I used an older version and still the same errors.BlueMac77 wrote:Hi. Maybe you can try the options below and hope they fixed the problem.gamingguy5000 wrote:No other ideas?
/download/old/
