Multiple Titles Trouble
HnyBear
Post by HnyBear »
I have a DVD with 2 titles on it. I've already been using iso files on my HDD for these DVDs but am trying to remux them to mkv. If I use the iso image on the HDD it only shows one title at 1.9GB if I use the DVD itself it shows both titles, 1.9GB and 2.2GB.
How do I get MakeMKV see both titles in the iso file so I can speed up the process?
Re: Multiple Titles Trouble
Without a log file, it is rather hard to guess. Do you have debug logging turned on?
HnyBear
Post by HnyBear »
No, I don't. I used another program to get around the problem. Thank you for your response. I'd try to troubleshoot it but no longer have the iso file.
For what it is worth, leaving debug logging on doesn't slow ripping down, so it's a good thing to do in general.
As for working with ISOs, I've found that how the ISO is created has a lot to do with how it works. An actual disk image ISO usually works fine, but some ISOs are created with some stuff decrypted, or otherwise modified. It's difficult to predict whether or not those will work.
