G.I Joe Rise of the Cobra & Retaliation
I updated MakeMKV to 1.12.3 before doing a undecrypted back up of the above UHD discs, and it produced a lot of Verification errors, I reverted back to previous version and the discs backed up without any error
Heaven Won't Have Me & Hells Afraid I Will Take Over
Lovely Rita
Re: G.I Joe Rise of the Cobra & Retaliation
And the list of errors, the would help the developer troubleshoot, were.......?
I will have to reinstall 1.12.3 to do that but will try it and see if a fresh install does the same. and post ithe list here if it doesLovely Rita wrote:And the list of errors, the would help the developer troubleshoot, were.......?
list of errors for one of the discs attached
- MakeMKV Errors list.txt
- (55.54 KiB) Downloaded 1291 times
The extreme number of hash check failures would make me think the hash table itself was corrupt. But Mike would have to be the judge of that.
It was the same for both GI Joe Discs with 1.12.3 once I reverted back to 1.12.2 everything was fine no errors
So it make me think its something in 1.12.3 thats causing it
- Contact:
Is this happening on a single disc only? This is certainly a bug, the output is bizarre...Hash check for /BDMV/STREAM/00068.m2ts : 99.99% corrupt, 0% correct, 193.92% checked
Mike, here's another that may be related:mike admin wrote:Is this happening on a single disc only? This is certainly a bug, the output is bizarre...Hash check for /BDMV/STREAM/00068.m2ts : 99.99% corrupt, 0% correct, 193.92% checked
http://www.makemkv.com/forum2/viewtopic ... 12&t=17775
After reverting back to the older version of MakeMKV I havn't updated it since to try with any other discsmike admin wrote:Is this happening on a single disc only? This is certainly a bug, the output is bizarre...Hash check for /BDMV/STREAM/00068.m2ts : 99.99% corrupt, 0% correct, 193.92% checked
I will wait for the next update and try discs again to see if whatever the course is still present.
tribunal88
Update: I apologize. Neither of these are UHD disks. I found this thread through a link and didn't check the forum header. It's still a bug, but I'll repost it in the proper forum.
I get a milder form of this error:
However, despite this it seemed to let me rip the files properly. Here are some expanded comments I had from a different thread:
Hash check failed for file 00800.m2ts at offset xxxxxxx, file is corrupt.
Too many hash check errors in file 00800.m2ts.I just experienced the same thing, coincidentally on the Infinity War disk (region-free international version). I ripped the 2D and 3D versions of the film and both threw this error throughout the initialization process, and then just at the beginning of the rip. They both ripped successfully and seemed to play fine, though I'd have to do a full viewing to know for sure.
I then tested my Black Panther disks which I knew were ripped properly a few months back and I've done a full viewing of that film. The same strange errors presented during initialization and at the beginning of the rip.
I decided to try reverting to 1.12.2, and the errors went away on all disks.
Low Winter Sun
I had same issue with Cars 3 UHD. 12.2.3 failed with a hash check error on an ASUS drive, and a LG drive. Reverting back to 12.2.2 and it ripped fine with no errors.
Hey did these ever get released in the US?
Nope. Paramount cancelled the US release.... for now.
