When creating an MKV file I routinely skip added (optional) features of DVDs including all short (less than 3 minutes) titles and save only the main movie file. But I very much would like to save the top level DVD start menu together with the main feature. This would be helpful to investigate available setup options (language, subtitle, etc.) Is this possible, and if it is how can I do it?
Regards
Creating/saving top level DVD menu
Re: Creating/saving top level DVD menu
There is no provision in the MKV file format for saving menu information, which makes it difficult to do that, though.
PeacePipe
Thanks, it's good to know that. There are times when a feature may not justify the efforts to implement it.
