Error Ripping Blu-Rays
gamingguy5000
Post by gamingguy5000 »
I'm using an LG BH12LS38 Blu-Ray drive connected via a Anker USB 3.0 to SATA Portable Adapter and I'm getrting the following across all of my blu-rays but no issues with regular DVD's.
MakeMKV v1.12.3 win(x64-release) started
Evaluation version, 24 day(s) out of 30 remaining
Error 'Scsi error - ILLEGAL REQUEST:SYSTEM RESOURCE FAILURE' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:\Users\Fury/.MakeMKV/MKB_v46_MARVEL'S_CAPTAIN_AMERICA_THE_WINTER_SOLDIER_-_BLU-RAY_561E.tgz
Any suggestions?
Thank you.
Re: Error Ripping Blu-Rays
The most common cause of this (other than a real revocation) is that MakeMKV was not able to read the part of the BD that contains key information. Are you running MakeMKV with administrator privileges?
gamingguy5000
Woodstock wrote:The most common cause of this (other than a real revocation) is that MakeMKV was not able to read the part of the BD that contains key information. Are you running MakeMKV with administrator privileges?
Yes, I am.
gamingguy5000
No other ideas?
BlueMac77
Post by BlueMac77 »
gamingguy5000 wrote:No other ideas?
Hi. Maybe you can try the options below and hope they fixed the problem.
• Try a different older version of MakeMKV
• If you can borrow a different optical drive or different computer to check
• Clean the blu-ray disc
I encountered this same problem once, I reverted to an older version of MakeMKV and this solved the problem.
gamingguy5000
So I used an older version and still the same errors.
/download/old/
