Ready One Player cant rip
tonylau1970
please help
- MKB20_v61_READY_PLAYER_ONE_8976.tgz
- (3.18 MiB) Downloaded 747 times
Re: Ready One Player cant rip
You NEED to READ and follow the instructions here:
http://www.makemkv.com/forum2/viewtopic ... 12&t=16883
No use/help in posting the dump in these forum.
Additionally I am almost positve that Mike has the dump for at least one additonal variation of this disc which he has yet to add support on. But I am positive it/additional keys for this are coming. Patience.
I ripped this the day it came out. Make sure you updated your keys file.
James_Kellard
Good evening
Really having trouble ripping Ready Player One UHD UK version, even tried the link for the .tgz file. MKV loads the disk after a while then gets stuck trying to unencrypt, I know its the hash key but does anyone have a key that has worked for them please
appreciate the help
James
appreciate the help
James
If you are trying to download the file attached above to the first post in this thread to try and make your disc work, well... that’s never going to work. Because that is not how this process works. Read this post:James_Kellard wrote: ↑Sat Feb 08, 2020 9:12 pmGood evening
appreciate the help
James
https://www.makemkv.com/forum/viewtopic ... 389#p83389
If you are getting that same “volume key is unknown” error, then the exact same applies to you and you need to do as it’s discussed there.
If you are getting a different error, then you will need to provide more information on that so that members can advise if possible.
Additionally, forum search function works. Use it. It will often provide quick answers to common questions/errors.
https://www.makemkv.com/forum/search.ph ... is+unknown
