UHD drives
Locked
jonghotti
Re: Please read my message - no more drive available from me
Post by jonghotti »
KBJghost
Re: UHD drives
Post by KBJghost »
^What?
jonghotti
Re: UHD drives
Post by jonghotti »
KBJghost wrote:^What?
May not have taken my meds yesterday.
KBJghost
Re: UHD drives
Post by KBJghost »
Cheers!
IITravel01
Re: UHD drives
Post by IITravel01 »
Hello.
So, I'm building a hackintosh. Listed as an optical drive that's hackintosh friendly is the LG WH14NS40. I ordered one from Amazon and got the NS50 version but with ROM 1.03 with a Jan. 2018 build date on the sticker. OK, so I hadn't seen this drive as UHD friendly, but doing a search I came across this thread where multiple people have confirmed this older (WH14, not 16) drive is "friendly" which is good news for me (and should be updated on some sites hopefully), but the bad news is the 1.03 firmware installed. So all I need to do is downgrade the firmware to 1.02, and no I don't want to convert the firmware to the Asus 3.02 as I don't see that listed as hackintosh friendly. That's where I'm at, so what's the easiest why to go from 1.03 firmware to 1.02 on the LG WH14NS40 (NS50) blu-ray drive?
st4evr
Re: UHD drives
Post by st4evr »
IITravel01 wrote:Hello.
http://www.makemkv.com/forum2/viewtopic ... 16&t=17058
It’s the method(s) for all compatible friendly drives. Including that drive.
IITravel01
Re: UHD drives
Anyone try to cross update the firmware of a LG 1.03 to the Asus 3.02 and then back again to the LG 1.02?
jonghotti
Re: UHD drives
Post by jonghotti »
IITravel01 wrote:
Sat Jul 28, 2018 6:33 pm
I have actually done this now, and it worked fine. loading the LG with the ASUS firmware seemed to unlock the higher speed the ASUS is known for. the unit is now sitting at the stock LG 1.02
IITravel01
Re: UHD drives
jonghotti wrote:
Mon Aug 13, 2018 1:53 pm
OK, did you upgrade to the Asus using the simple cross upgrade firmware for the Asus drive? If so, then what software did you downgrade back to the LG 1.02 firmware? The reason I was wondering if anyone had done this was to see if the Asus to LG firmware downgrade from 3.02 to 1.02 required all the procedures that doing the LG 1.03 to 1.02 needed (appears simple to cross upgrade with the Asus firmware tool, but going back was my question), or if since the LG didn't notice that it was downgrading because it doesn't see 1.03, just allowed you install 1.02?
jonghotti
Re: UHD drives
Post by jonghotti »
Let me clarify, I’ve put the ASUS firmware on the LG but not vice versa.
As the ASUS is better firmware I have verified the LG loaded with ASUS will achieve the faster read speeds.
jonghotti
Re: UHD drives
Post by jonghotti »
I would never, obviously, send anyone an
LG branded drive loaded with ASUS firmware as I’ve not tested every possible use case.
Marcus_UHD
Re: UHD drives
Post by Marcus_UHD »
Has anyone had any success reading UHD disk with the ASUS BW-16D1X-U?
st4evr
Re: UHD drives
Post by st4evr »
Marcus_UHD wrote:
Wed Aug 15, 2018 11:14 pm
Forum search function works:
viewtopic.php?f=16&t=16832&p=63930&hili ... X+U#p63930
jonghotti
Seriously
Post by jonghotti »
I seriously would send a moderator a bottle of Jack Daniels to delete my jonghotti mult on here.
These searches that return all my “didn’t take my psych meds today” posts are embarrassing as fuck.
Re: Seriously
Post by d00zah »
jonghotti wrote:
Thu Aug 16, 2018 12:33 am
:lol:
Locked
