Unable to convert "The Other Guys"
EmoNorris
#1 Post by EmoNorris » Thu Mar 24, 2011 2:36 pm
Attempting to dump any of the 4 main movie parts results in a failure. Let me know if I need to attach anything else.
I've attached the log as a txt file.
hursto75
Re: Unable to convert "The Other Guys"
#2 Post by hursto75 » Fri May 06, 2011 3:30 pm
Same issues here.
netwrxman
#3 Post by netwrxman » Mon Jul 23, 2018 1:31 am
Resurrecting this old thread as I seem to be having the same issues as the other two. I searched for other threads but not seeing any updated info for Bluray.
netwrxman
#4 Post by netwrxman » Fri Jul 27, 2018 1:11 am
Any suggestions here? I know this is an old thread, but I was hoping to get the conversion working on this movie.
#5 Post by Woodstock » Fri Jul 27, 2018 3:07 pm
The original post from 7 years ago had (at the time) a log that showed what was happening. Without that, any response is a wild guess.
I try to avoid those.
EPiPH0N3
#6 Post by EPiPH0N3 » Sun Aug 12, 2018 1:35 am
Since this is the funniest movie to have come out in this millennia, which is sad cause it's from 8 years ago, I grabbed a copy from Amazon and full disc backup worked fine and unrated MKV rip went fine using MakeMKV v1.12.3 linux(x64-release). The only thing that came up during the MKV rip was this, which I have never seen before, but it didn't prevent the rip from completing:
AV sync issue in stream 1 at 0:10:43.476 : audio changes from 16bps to 24bps, you won't be able to convert this track to any other format later, please use a conversion profile with audio transcoding
Not sure what u guys r on about.
