This disc requires Java runtime (JRE), but none was found.
beatsntoons
#1 Post by beatsntoons » Sun Jul 22, 2018 6:48 am
Hi there
I got the following message today, ripping Pacific Rim Uprising.
"This disc requires Java runtime (JRE), but none was found. Certain functions will fail, please install Java"
After reading MakeMKV's webpage about this (/bdjava/) but I'm still not entirely clear if I need it. The movie looks like it ripped fine. I don't have Java, and the scenes all appear in order.
Would there be another reason this message appears?
Re: This disc requires Java runtime (JRE), but none was foun
#2 Post by mike admin » Sun Jul 22, 2018 10:14 pm
beatsntoons wrote:Would there be another reason this message appears?
MakeMKV detected extended metadata in java code. You will get proper file names if you have java installed, even just for MakeMKV.
beatsntoons
#3 Post by beatsntoons » Mon Jul 23, 2018 1:41 am
thanks Mike. So it'll just be file names... that's okay then, I can live with incorrect file names. I can always rename them myself, no?
beatsntoons
#4 Post by beatsntoons » Wed Jul 25, 2018 8:42 am
Actually, Mike, it looks like the program created an extract (even though successfully copied)
Did you want to see it at all? Or can I assume all is fine?
