This disc requires Java runtime (JRE), but none was found.
beatsntoons
Post by beatsntoons »
Hi there
I got the following message today, ripping Pacific Rim Uprising.
"This disc requires Java runtime (JRE), but none was found. Certain functions will fail, please install Java"
After reading MakeMKV's webpage about this (/bdjava/) but I'm still not entirely clear if I need it. The movie looks like it ripped fine. I don't have Java, and the scenes all appear in order.
Would there be another reason this message appears?
Re: This disc requires Java runtime (JRE), but none was foun
Post by mike admin »
beatsntoons wrote:Would there be another reason this message appears?
MakeMKV detected extended metadata in java code. You will get proper file names if you have java installed, even just for MakeMKV.
beatsntoons
thanks Mike. So it'll just be file names... that's okay then, I can live with incorrect file names. I can always rename them myself, no?
beatsntoons
Actually, Mike, it looks like the program created an extract (even though successfully copied)
Did you want to see it at all? Or can I assume all is fine?
