Mkv File - Sound and Picture are not in Sync
Kurejitto
#1 Post by Kurejitto » Fri Jul 20, 2018 3:13 pm
Hello everyone, I have the following problem.
Whenever I start the finished mkv file with the VLC Player the picture hangs but the sound continues to run.
The Picture and the Sound re-sync when i push the Time Forward Button.
Where is the Mistake ??? Can u Help ??
Thanks!!
Re: Mkv File - Sound and Picture are not in Sync
#2 Post by Woodstock » Fri Jul 20, 2018 4:46 pm
How recent is your version of VLC? Different versions have different problems with video and audio codecs. If your system supports hardware acceleration, make sure that is turned on.
Kurejitto
#3 Post by Kurejitto » Fri Jul 20, 2018 5:05 pm
Hi and Thanks for your Answer! I have the Latest Version of MakeMKV 1.12.2.
Hardware Acceleration is Enabled. I also got the Latest Version of VLC Media Player.
My graphics card drivers are also up to date.
I recently changed my OS. From Windows 7 32 bit to Windows 7 64 bit.
Can it have something to do with it? Or is it really the codecs?
Thanks for the answer.
