Configuration
satkid
Configuration
Post by satkid »
Hi, Every time I load a disk and go into the options to do the extract I never get the DTS-HD master ticked, its always the DTS option. Is there a setting somewhere that needs to be applied to always pick this option?
Also in the tick boxes for audio and subtitles is there a way of selecting all and unselecting, as finding having to untick all rather than the options I require. Same as everytime forced subtitle only and HD audio.
Thanks,
st4evr
Re: Configuration
Post by st4evr »
Thanks,
See here:
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=17502
The forum search function does work.
