Hello everyone, I have the following problem.
Whenever I start the finished mkv file with the VLC Player the picture hangs but the sound continues to run.
The Picture and the Sound re-sync when i push the Time Forward Button.
Where is the Mistake ??? Can u Help ??
Thanks!!
Mkv File - Sound and Picture are not in Sync
Kurejitto
Re: Mkv File - Sound and Picture are not in Sync
How recent is your version of VLC? Different versions have different problems with video and audio codecs. If your system supports hardware acceleration, make sure that is turned on.
Kurejitto
Hi and Thanks for your Answer! I have the Latest Version of MakeMKV 1.12.2.
Hardware Acceleration is Enabled. I also got the Latest Version of VLC Media Player.
My graphics card drivers are also up to date.
I recently changed my OS. From Windows 7 32 bit to Windows 7 64 bit.
Can it have something to do with it? Or is it really the codecs?
Thanks for the answer.
