Hello, can someone help interpret the following error information? I've also copied my drive information, which displays "No disc inserted" after the failure and renders my BD drive unable to open unless I unplug/plug (my drive's inside a NexStar DX and connected to my laptop via USB 3.0):
Saving 1 titles into directory
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '456130560'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '456130560'
Failed to save title 0 to file /Users/John/Desktop/Holding/Ramen Girl, The/The_Ramen_Girl_t00.mkv
0 titles saved, 1 failed
OS device name: /dev/rdisk5
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.03
Serial number: K9FI3FC1314
Firmware date: 2118-01-19 15:58:
Bus encryption flags: 1F
Highest AACS version: 63
The Ramen Girl - Failed to Save
NambanRonin
Re: The Ramen Girl - Failed to Save
Update: I've used a different drive (portable DVD writer) and successfully saved (however, not without errors). I've posted the drive info and errors below.
Can anyone help as to why my first drive was unsuccessful?
Product: DVDRAM GP60NS50
Revision: PE00
Serial number: KX0Z2PH3843
Firmware date: 2016-01-14 17:16:
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617115648-617146368, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617181184-617211904, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617279488-617310208, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617347072, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617353216-617357312, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617363456, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617418752-617441280, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617476096-617480192, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617486336, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617494528, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617498624-617500672, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617506816, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617541632-617572352, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617607168-617609216, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617623552, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617635840, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617639936-617670656, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617707520-617736192, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617773056-617801728, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617836544-617867264, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617902080-617932800, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617967616-618006528, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618012672, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618022912, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618027008, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618065920-618096640, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618131456-618133504, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618141696, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618147840, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618151936, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618196992-618227712, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618262528-618264576, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618270720, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618291200, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618328064-618358784, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618397696-618457088, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618473472-618489856, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618524672-618526720, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618549248, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618590208-618620928, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618688512-618719232, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618756096-618784768, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618819584-618850304, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618885120-618915840, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618950656-618981376, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 619048960-619053056, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 619075584, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 619116544-619145216, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 619409408-619440128, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 617953280, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618139648-618141696, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 618940416, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 619464704, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 619878400, attempting to work around
1 titles saved
Revision: PE00
1 titles saved
rivey
Your original drive is an Asus drive with firmware v3.03. That firmware will not work with UHD discs. It is not UHD friendly. You only solution for the drive is to downgrade the firmware to 3.00 or 3.01. TedRaspin has posted the instructions on how to do it.NambanRonin wrote:Update: I've used a different drive (portable DVD writer) and successfully saved (however, not without errors). I've posted the drive info and errors below.
Also, do a forum search on "friendly UHD" drives for more info.
Lovely Rita
Hmmm......must be a specially authored UHD since it had VOB files.rivey wrote:Your original drive is an Asus drive with firmware v3.03. That firmware will not work with UHD discs. It is not UHD friendly. You only solution for the drive is to downgrade the firmware to 3.00 or 3.01. TedRaspin has posted the instructions on how to do it.
You’ve been so busy answering UHD drive posts you overlooked that his issue is with a DVD.
Hint: this is the DVD section.
NambanRonin
Yes, Lovely Rita is correct, the disc in question is a DVD. Thanks both for your replies.
I'd appreciate it if anyone can interpret the error messages!
Lovely Rita wrote:Hmmm......must be a specially authored UHD since it had VOB files.rivey wrote:Your original drive is an Asus drive with firmware v3.03. That firmware will not work with UHD discs. It is not UHD friendly. You only solution for the drive is to downgrade the firmware to 3.00 or 3.01. TedRaspin has posted the instructions on how to do it.
Also, do a forum search on "friendly UHD" drives for more info.![]()
