Chappaquiddick - failed to copy
RickInHouston
Post by RickInHouston » Tue Jul 10, 2018 2:48 pm
One word - Lionsgate.
Has anyone had any success with this disc?
outdoorguy568
Re: Chappaquiddick - failed to copy
Post by outdoorguy568 » Tue Jul 10, 2018 10:03 pm
Also have an issue with this disk... log file attached.
MakeMKV_log.txt
(19.24 KiB) Downloaded 1129 times
RickInHouston
Post by RickInHouston » Wed Jul 11, 2018 2:25 pm
Here is a second log file.
MakeMKV_log.txt
(31.87 KiB) Downloaded 1175 times
rivey
Post by rivey » Wed Jul 11, 2018 6:12 pm
Are these brand new discs or older?
I am not sure but I think the log is showing uncorrectable errors.
The first thing I would try is to clean the discs. I make it a habit with every disc I rip to clean the disc first. I used a 50/50 mix of distilled water and rubbing alcohol and a microfiber cloth. I stopped having problems after I started doing this.
It might not be your problem, but it is a good place to start. Good Luck
RickInHouston
Post by RickInHouston » Wed Jul 11, 2018 6:16 pm
New discs. I did clean the first disc, but it looked to be brand new. It also played fine in PowerDVD and VLC. I actually tried a second disc of the same movie thinking it was just the disc - but also a no go. The log file I provided was the second disc that failed.
rivey
Post by rivey » Wed Jul 11, 2018 9:21 pm
RickInHouston wrote:New discs. I did clean the first disc, but it looked to be brand new. It also played fine in PowerDVD and VLC. I actually tried a second disc of the same movie thinking it was just the disc - but also a no go. The log file I provided was the second disc that failed.
Although a new disc may look perfectly clean, many times they are not. It can't hurt to give it a try and see if it helps. Since I started cleaning every disc, I have not had any problems other than sending the log to Mike for decryption. Many others have thought there discs were clean but when we told them to clean them, the disc was able to be ripped. Good Luck
outdoorguy568
Post by outdoorguy568 » Wed Jul 11, 2018 9:29 pm
New Disk and cleaned also. People were having issues using another program to rip it... they just resolved that issue.
RickInHouston
Post by RickInHouston » Thu Jul 12, 2018 3:50 pm
Have all attempts at correcting this protection been exhausted? Is this going to be an official 'no go'?
eddie812
Post by eddie812 » Thu Jul 12, 2018 5:44 pm
I tried ripping Chappaquiddick several times and was unsuccessful too. The disc was pristine in appearance before and after cleaning it.
Lovely Rita
Post by Lovely Rita » Thu Jul 12, 2018 5:55 pm
RickInHouston wrote:Have all attempts at correcting this protection been exhausted? Is this going to be an official 'no go'?
I wouldn’t go that far. There’s only one person here that can make sense of the log files and update the app and we don’t know if he’s even looked at this yet. :wink:
Depending on your situation:
Retail copy - put it on the shelf until resolved.
Rental - return and try again later.
Registered User :wink:
Buy MakeMKV
RickInHouston
Post by RickInHouston » Fri Jul 20, 2018 2:29 pm
Anything to report?
Bump.
debof14
Post by debof14 » Fri Jul 20, 2018 5:39 pm
939 seems to be the winner for Netflix version
Lovely Rita
Post by Lovely Rita » Fri Jul 20, 2018 10:18 pm
debof14 wrote:939 seems to be the winner for Netflix version
You're referring to the BluRay?
This is the DVD section. :wink:
Buy MakeMKV
Lovely Rita
Post by Lovely Rita » Sat Jul 21, 2018 5:54 pm
Debug log started at Sat Jul 21 16:54:21 2018 , written by MakeMKV v1.12.2 darwin(x64-release)
001005:0000 MakeMKV v1.12.2 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/admin/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE PIONEER BD-RW BDR-208D 1.10d" opened in OS access mode.
001003:0020 DEBUG: Code 100864261 at iXWujWp2E]d>xMLE:121269823
003028:0000 Title #1 was added (20 cell(s), 1:49:07)
003025:0000 Title #2 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #3 has length of 15 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #4 has length of 23 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #5 has length of 8 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #6 has length of 13 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #7 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #8 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #9 has length of 1518 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #10 has length of 765 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #11 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #12 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #13 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #14 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #15 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #16 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #17 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #18 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #19 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #20 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #21 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #22 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #23 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #24 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #25 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #26 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #27 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #28 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #29 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #30 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #31 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #32 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #33 has length of 121 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #34 has length of 121 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #35 has length of 121 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #36 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #37 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #38 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #39 has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #40 has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #41 has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #42 has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
DEBUG: Code 352321796 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=21 pgcn=1 hash=7B806A58EDE6CCA4
DEBUG: Code 369099268 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=2 hash=65727360D9938346
DEBUG: Code 369099524 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=3 hash=4A999ABFAE4DF691
DEBUG: Code 369099780 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=4 hash=467B0391F56071F9
DEBUG: Code 369100036 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=5 hash=62000FB2EA06778F
DEBUG: Code 369100292 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=6 hash=E823A47921FAF031
DEBUG: Code 369100548 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=7 hash=A922419020E17947
DEBUG: Code 369100804 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=8 hash=5C0D14482D726AC8
DEBUG: Code 369101060 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=9 hash=BD4E5A27D0BFD63E
DEBUG: Code 369101316 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=10 hash=5B80E1C972AAED10
DEBUG: Code 369101572 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=11 hash=6D5F496817474F7E
DEBUG: Code 369101828 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=12 hash=FBB6CFEB674E6425
DEBUG: Code 369102084 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=13 hash=A9EF773DD244EBE3
DEBUG: Code 369102340 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=14 hash=D86C927F897AF94E
DEBUG: Code 369102596 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=15 hash=7C4518EFA523B1BD
DEBUG: Code 369102852 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=16 hash=05009826793E866A
DEBUG: Code 369103108 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=17 hash=594170157A66AA50
DEBUG: Code 369103364 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=18 hash=3892B92B59FC7659
DEBUG: Code 369103620 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=19 hash=279AA1AA7340DC81
DEBUG: Code 369103876 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=20 hash=87F0216629AB9461
DEBUG: Code 369104132 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=21 hash=6F14A6398C2CA606
DEBUG: Code 369104388 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=22 hash=0418FCEA7842DF77
DEBUG: Code 369104644 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=23 hash=A65E3493C25F1733
DEBUG: Code 369104900 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=24 hash=AC8AA5FC83DAC9FD
DEBUG: Code 369105156 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=25 hash=0715832968BD628A
DEBUG: Code 369105412 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=26 hash=29E3998B1A9C905F
DEBUG: Code 369105668 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=27 hash=7ECC2F491113E28E
DEBUG: Code 369105924 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=28 hash=F24F716B0209E7D8
DEBUG: Code 369106180 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=29 hash=D99BF476F5A1BC0E
DEBUG: Code 369106436 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=30 hash=2415BE290A31A0FA
DEBUG: Code 369106692 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=31 hash=FDAAFD69540ED741
DEBUG: Code 369106948 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=32 hash=F0FF0BB4763D29B0
DEBUG: Code 369107204 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=33 hash=81899FDEAA563465
DEBUG: Code 369107460 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=34 hash=4A648BDD20469389
DEBUG: Code 369107716 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=35 hash=B466E0C7C1015376
DEBUG: Code 369107972 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=36 hash=B55BCCD4DC78FA7F
DEBUG: Code 369108228 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=37 hash=3ACC17AF0672C356
DEBUG: Code 369108484 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=38 hash=3CC9BDD577EBB621
DEBUG: Code 369108740 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=39 hash=D8072EB8B1F37611
DEBUG: Code 369108996 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=40 hash=14E6CF4BC7AC7425
DEBUG: Code 369109252 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=41 hash=713021B1D29D9C4A
DEBUG: Code 369109508 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=42 hash=86CDE1EA86C58B1E
DEBUG: Code 369109764 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=43 hash=D1ACA85C3C3DAC6D
DEBUG: Code 369110020 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=44 hash=58F00D484579C4B2
DEBUG: Code 369110276 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=45 hash=0D9F568DF79E9328
DEBUG: Code 369110532 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=46 hash=56B8D62C8C782016
DEBUG: Code 369110788 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=47 hash=0EA7C3410ABEC67A
DEBUG: Code 369111044 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=48 hash=FB0DBF076F19DEDD
DEBUG: Code 369111300 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=49 hash=ACE6142758344847
DEBUG: Code 369111556 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=50 hash=203A40380E39EE4D
DEBUG: Code 369111812 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=51 hash=D9F04767AA7A7A23
DEBUG: Code 369112068 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=52 hash=E78BF5C7F22EB9D8
DEBUG: Code 369112324 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=53 hash=1ABE313CEAED5B00
DEBUG: Code 369112580 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=54 hash=56F877CEB579B69F
DEBUG: Code 369112836 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=55 hash=3247A0D98C4BFEBE
DEBUG: Code 369113092 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=56 hash=FB9EFD183E2A4ED9
DEBUG: Code 369113348 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=57 hash=423D75395CF5182F
DEBUG: Code 369113604 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=58 hash=F77C0E3409420496
DEBUG: Code 369113860 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=59 hash=520FEC059B63140B
DEBUG: Code 369114116 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=60 hash=9769EB6E97A4CE41
DEBUG: Code 369114372 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=61 hash=5F922A3DFAFAAA69
DEBUG: Code 369114628 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=62 hash=35638C2149B85AAB
DEBUG: Code 369114884 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=63 hash=C54026F6251D4E0B
DEBUG: Code 369115140 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=64 hash=0551A03466EE9713
DEBUG: Code 369115396 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=65 hash=329B0F923E57A35C
DEBUG: Code 369115652 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=22 pgcn=66 hash=D9B94C7A4F8729BB
003025:0000 Title #44/66 has length of 2 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003028:0000 Title #45 was added (20 cell(s), 1:49:07)
Title skip vts=24 pgcn=1 hash=A1EDFEBEEEB825C9
001003:0020 DEBUG: Code 32813 at rYQZr,E3"A/xA$:213133158
003019:0000 Cells 2-4 were skipped due to cell commands (structure protection?)
003028:0000 Title #47 was added (19 cell(s), 1:46:48)
001003:0020 DEBUG: Code 10551301 at Q-?[4W'q!#TYj"^;:213142496
001003:0020 DEBUG: Code 0 at Q-?[4W'q!#TYj"^;:121274998
001003:0020 DEBUG: Code 0 at Red!O]>RF a_d|@Ed+:29394229
003035:0000 CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
003037:0000 Cells 1-1 were removed from title start
003028:0000 Title #48 was added (18 cell(s), 1:46:29)
003028:0000 Title #49 was added (18 cell(s), 1:46:29)
003028:0000 Title #50 was added (18 cell(s), 1:46:29)
003028:0000 Title #51 was added (19 cell(s), 1:44:39)
003028:0000 Title #52 was added (19 cell(s), 1:44:12)
003028:0000 Title #53 was added (19 cell(s), 1:44:09)
Title skip vts=1 pgcn=1 hash=5C14F8D038F375CE
003028:0000 Title #55 was added (18 cell(s), 1:46:29)
003028:0000 Title #56 was added (18 cell(s), 1:46:29)
003028:0000 Title #57 was added (20 cell(s), 1:49:07)
003028:0000 Title #58 was added (20 cell(s), 1:49:07)
DEBUG: Code 536871431 at Q-?[4W'q!#TYj"^;:121266189
Title skip vts=32 pgcn=2 hash=2BF8BAF7A87581A9
003027:0000 Title 1 in VTS 34 is equal to title 1 and was skipped
003027:0000 Title 1 in VTS 26 is equal to title 1 and was skipped
Title 02 is the ONLY one of the six that copies with no errors.
The rest display AV Sync Issues and Corrupt or Invalid VOB at Offset.........
Buy MakeMKV
RickInHouston
Post by RickInHouston » Tue Jul 24, 2018 2:47 pm
The above post is correct. This has been corrected and is now working.
