Justice League 3D - Crashes MakeMKV
Everything related to Blu-ray 3D and 3D MKV files
Krobar
Post by Krobar »
2D Version is OK.
3D Version starts to load and even shows the titles in the background as the app crashes. Debug log attached; can anyone help?
MakeMKV_log.txt
(5.95 KiB) Downloaded 1108 times
Re: Justice League 3D - Crashes MakeMKV
Are there any Windows events associated with the crash?
This is likely something that will have to be sent directly to Mike via email, support@makemkv.com . Send the items listed in the FAQ link in my signature, along with any Windows events associated with it.
Krobar
Post by Krobar »
Woodstock wrote:Are there any Windows events associated with the crash?
Nothing in the Windows App or System logs. Makemkv is crashing for all disks now; finishes the disc status bar and then crashes as the title checkboxes should appear (As you click to close the program it gives a glimpse of the titles). If anyone could help I would appreciate it.
Krobar
Post by Krobar »
Eventually found a solution to this. You need to install an older version of Makemkv and then reinstall the current version. Just reinstalling the current version did not help.
