Does MakeMKV permanently remove protection on Blu Rays?
chococookie891
Post by chococookie891 » Sun Jul 08, 2018 10:10 pm
I understand MakeMKV decrypts blu ray files. Does MakeMKV alter the contents on the physical disc itself in any way? Once MakeMKV rips the contents of the disc, is the protection/DRM on the disc permanently removed?
st4evr
Re: Does MakeMKV permanently remove protection on Blu Rays?
Post by st4evr » Sun Jul 08, 2018 11:09 pm
No decryption/ripping software works like that. This includes MakeMKV. You are misunderstanding how decrytion of BDs work in this sense then.
The short version. No. The media on the ORIGINAL RETAIL movie disc is static and the physical disc itself remains unmodified. Movie studios use physical discs that are recordable. NOT rewritable. All protections will remain on the disc for as long as the disc exists. Whether you use MakeMKV or other ripping software on the market.
The long version? Google.
chococookie891
Post by chococookie891 » Mon Jul 09, 2018 12:19 am
st4evr wrote:No decryption/ripping software works like that. This includes MakeMKV. You are misunderstanding how decrytion of BDs work in this sense then.
Thanks for the explanation! Yeah, I don't really understand it. I did some googling and it's kind of going over my head. So ripping software generate a key to decrypt the Blu Ray that allows them to rip/copy the contents, but it leaves the actual container, or protection, intact? If MakeMKV is run on the same copy of a disc more than once, will it have to decrypt the the BD each time because the DRM is still intact?
drathbun
Post by drathbun » Mon Jul 09, 2018 12:29 am
chococookie891 wrote:If MakeMKV is run on the same copy of a disc more than once, will it have to decrypt the the BD each time because the DRM is still intact?
It runs the same process each time, yes.
chococookie891
Post by chococookie891 » Mon Jul 09, 2018 12:41 am
Thanks! I see, and BD players, such as a PS4, verify the DRM before running it?
st4evr
Post by st4evr » Mon Jul 09, 2018 2:39 am
Yes, there is a handshake that occurs between players and media for various purposes. Including varifying protection (if any).
