Can't open any file
jpb02
Can't open any file
Post by jpb02 »
cos' makemkv begins with searching cdrom reader, and opening file is greyed.
Thanks for your help
jpb
Re: Can't open any file
If the drive is open, MakeMKV should detect that it is empty, and not spend a lot of time trying to read anything from it. If it does, the operating system may be telling it, "Yeah, there's a disk here."
When was the last time you restarted the computer, in case the OS is confused?
jpb02
Post by jpb02 »
Woodstock wrote:If the drive is open, MakeMKV should detect that it is empty, and not spend a lot of time trying to read anything from it. If it does, the operating system may be telling it, "Yeah, there's a disk here."
I did restart the computer just before launching makemkv...
And I can't access preferences, which is also greyed
Thanks for your answer !
jpb02
Post by jpb02 »
It was effectively a problem with the CD reader. I did not use it for years. I could not open it normally with the "eject" keypress. But when i opened it after a reboot, makemkv worked normally. I think I will remove it (mac pro early 2008)
