Dick Van Dyke blue ray
amirnabilkamelsaad
#1 Post by amirnabilkamelsaad » Fri Jul 06, 2018 11:15 pm
I have the Dick Van Dyke show Bluerays and most of the disks rip however a couple of disks don't work such as:
Season 2: disks, 2, 3
Season 3: disk 1
This is an example of the error message I'm getting for 2 of those disks:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:\Users\Saad Desktop/.MakeMKV/MKB_v33_The_Dick_Van_Dyke_Show_Season_2_Disc_2_D22A.tgz
Saved AACS dump file as C:\Users\Saad Desktop/.MakeMKV/MKB_v33_Dick_Van_Dyke_Show_Season_3_Disc_1_283C.tgz
I am currently using version 1.12.2 which is the lastest to this date, thanks.
MKB_v35_The_Dick_Van_Dyke_Show_Season_2_Disc_3_6C7E.tgz
(1.2 MiB) Downloaded 392 times
(1.23 MiB) Downloaded 376 times
(1.24 MiB) Downloaded 378 times
Re: Dick Van Dyke blue ray
#2 Post by Woodstock » Sat Jul 07, 2018 2:05 am
AACS v33 is VERY old, and MakeMKV has been able to handle it for a long time.
However, some things can stop that - one of them is mentioned in the log, and this is revocation of the key MakeMKV uses. Can you access ANY other Bluray right now, or does the drive refuse all BD?
The other thing that can cause issues is the drive having trouble reading the directory of the disk, where the information needed for the key exchange is stored. This can be a drive problem, or (more likely) a disk problem. There is a "sticky" topic at the top of this section dealing with typical disk errors.
amirnabilkamelsaad
#3 Post by amirnabilkamelsaad » Sat Jul 07, 2018 6:10 am
Woodstock wrote:AACS v33 is VERY old, and MakeMKV has been able to handle it for a long time.
These are the only DVDs ever to give me an abort error since I purchased the software
The disk is brand new, so never touched. The drive worked just fine for the other disks all 12 of them, I'll try to check out that sticky as you mentioned, thanks for the help.
