MakeMKV to Handbrake for 4K (UHD)???
richdmoore
Re: MakeMKV to Handbrake for 4K (UHD)???
#16 Post by richdmoore » Wed Jul 04, 2018 6:57 am
lcgrzy wrote:\
As a side note, if you are going to keep using Handbrake, I wouldn't recommend the pre-set that you are using. 2160p60 means the final file is going to have 60 frames per second, which is completely unnecessary and will probably add to the size of the file and the time it takes to convert. You will find that most of these movies are finished at 23.976 fps, so upping that to 60 is really pointless.
Small correction. In Handbrake, the normal presets (including the 2160p60 mentioned above) have the Peak Framerate VFR setting as default, will keep the framerate the same as the source (up to the set maximum of 60 fps in this case.)
Most movies are at 23.976 like you stated above, so being lower than the typical 30 or 60 frame rate setting, no conversions take place by using the peak framerate setting. I just tested this again with a movie conversion, the framerate was not changed during the conversion process.
https://handbrake.fr/docs/en/latest/tec ... rates.html
