FAILURE: Code 182 and 832
mr_david_o
Post by mr_david_o »
Just found this program yesterday and really like the simplicity. However when I try to run it reading from a DVD I get a FAILURE: Code 182 and then 832 and some code 0's and then a failed to save title to file.
I have tried this with several DVDs all with the same result.
If I look at the folder I can see the file being written there but after the error it is gone.
If I read a file from DVD Fab I do not get the problem.
I am using 1.4.1 beta
Cells 16-end were skipped due to cell commands (structure protection?)
Title #0 was added (15 cell(s), 1:39:53)
Title #1 was added (15 cell(s), 1:39:53)
Title #2 was added (15 cell(s), 1:50:11)
Title #3 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 with special attributes was skipped
Title #7 with special attributes was skipped
Title #8 with special attributes was skipped
Title #9 has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 with special attributes was skipped
Title #11 with special attributes was skipped
Title #12 with special attributes was skipped
Title #13 with special attributes was skipped
Title #14 with special attributes was skipped
Title #15 with special attributes was skipped
Title #16 with special attributes was skipped
Title #17 with special attributes was skipped
Title #18 with special attributes was skipped
Title #19 with special attributes was skipped
Title #20 with special attributes was skipped
Title #21 with special attributes was skipped
Title #22 with special attributes was skipped
Title #23 with special attributes was skipped
Title #24 with special attributes was skipped
Title #25 with special attributes was skipped
Title #26 with special attributes was skipped
Title #27 with special attributes was skipped
Title #28 with special attributes was skipped
Title #29 with special attributes was skipped
Title #30 with special attributes was skipped
Title #31 with special attributes was skipped
Title #32 with special attributes was skipped
Title #33 with special attributes was skipped
Title #34 with special attributes was skipped
Cell 81 was discarded (structure protection?)
Title #35 was added (80 cell(s), 0:06:40)
Cell 27 was discarded (structure protection?)
Title #36 was added (26 cell(s), 0:02:10)
Cell 66 was discarded (structure protection?)
Title #37 was added (65 cell(s), 0:05:25)
Title #38 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #39 with special attributes was skipped
Title #40 with special attributes was skipped
Title #41 with special attributes was skipped
Title 2 in VTS 1 is equal to title 1 and was skipped
Operation sucessfully completed
Saving 1 titles into directory F:/MakeMKV
FAILURE: Code 182 at 1TBvbzjF|+fqD6#Pz[CnH!:121261865
FAILURE: Code 832 at c\MX<[Rhgq(}h~L=N~b$):29394896
FAILURE: Code 0 at h?}"uX6>pi2&s%Nox'k:213130973
FAILURE: Code 0 at c\MX<[Rhgq(}h~L=N~b$):29395885
FAILURE: Code 0 at r-'tbk'_px 8{|y\H2&:213131456
Failed to save title 0 to file F:/MakeMKV/t00_Feature.mkv
0 titles saved, 1 failed
Re: FAILURE: Code 182 and 832
Post by mike admin »
What kind of DVD is that? Did you rip it with any particular program? The error means that DVD files are incorrect. Please provide some more details.
mr_david_o
The DVDs I tried were the original X-men movie, Journey to the Centre of the Earth and Journey to the Centre of the Earth 3D. All are original DVDs, region code 4 for Australia and PAL. The dump is from the X-men movie which is now a few years old, the other 2 have just been released here in Australia. Don't know any more details to give you.
The error only comes up if I use MakeMKV with the original DVDs, if I use DVD Fab first I have no problems reading the files with MakeMKV.
mr_david_o
mr_david_o wrote:The error only comes up if I use MakeMKV with the original DVDs, if I use DVD Fab first I have no problems reading the files with MakeMKV.
I have now tried another 5 DVDs and they have all worked, I have also re-tried X-men (incase I had changed something) but it still fails. I guess it was just a fluke that I tried 3 DVDs that did not work first up. Still it would be good to know why they did not work.
