Tomb Raider - Failed to open disc
Deano86
Post by Deano86 »
Anyone else run into a problem with this title? Volume key is unknown...disc uses a newer version of AACS protection...
Grauhaar
Re: Tomb Raider - Failed to open disc
Post by Grauhaar »
What MakveMKV Version is used?
Good Luck :)
Deano86
Post by Deano86 »
OK, that was weird...I am on 1.12.2 Anyway, I just totally closed Makemkv and then restarted and installed a much older disc... it was fine... then a newer disc with AACS version 63 and it loaded fine. And just now I reloaded Tomb Raider with AACS v65 and it looks to be fine again. I had even started getting the "current aacs host certificate revoked by drive" messages for anything I put in the drive. But now, all appears to be good again! Whew! Wonder what caused that? Oh well, when in doubt, reboot or restart.. duh.
