playback issue
immortal.axay
playback issue
Post by immortal.axay »
I have ripped following movies using MakeMKV 1.12.2 and external ASUS BW-16D1H-U.
They are playing with blur video.
Same issue was faced with IT, GIFTED, The Mummy 2017 using MakeMKV 1.12.0 and ASUS BW-16D1H-U (http://makemkv.com/forum2/viewtopic.php?f=3&t=17436)
What should I do to solve it ?
Need to update FW of external ASUS BW-16D1H-U (installed A201)?
Re: playback issue
The problem is not likely to be with MakeMKV - MakeMKV would usually delete the file if it couldn't read it properly (matching the hash codes included on the disk).
What are you using to play the files? Are they on a local hard drive, network drive (wired), or wireless network?
Video tearing like this is often the result of the video decoder not being able to keep up with the file's data rate, either because it is just slow, or the file isn't been read fast enough.
immortal.axay
Re: playback issue
Thanks for reply.
I am using KODI player. Movies are sorted on NAS device. Both device PC and NAS are on wired network (1Gbps).
Re: playback issue
Do the errors always occur at the same point? And if you copy the movie to the machine running Kodi, does the local copy have the same error in the same place?
There are a lot of points for this problem to pop up; eliminating each one helps point to the fix.
