Missing titles on older Banacek DVD
aspartz
#1 Post by aspartz » Mon Jun 25, 2018 12:04 am
I have a 2008 TVGuide release of Banacek season 2.
Disc two is supposed to have 3 independent titles and a 4th that is all three combined.
When I try to convert this with MakeMKV only the first two titles are shown. There are no unreadable sectors. The disc plays correctly on PowerDVD.
Any Ideas?
Re: Missing titles on older Banacek DVD
#2 Post by Woodstock » Mon Jun 25, 2018 12:37 am
The FAQ link in my signature will help you gather the information Mike will need to help on this. You can send it to support@makemkv.com
You could also post the debug log here for us non-Mike people to look at, and maybe we can see the problem. Just put it between "code" tags, and include it in a reply.
aspartz
#3 Post by aspartz » Mon Jun 25, 2018 5:28 am
Debug log started at Mon Jun 25 04:51:08 2018 , written by MakeMKV v1.12.2 win(x64-release)
001005:0000 MakeMKV v1.12.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\aspartz/MakeMKV_log.txt
003028:0000 Title #1 was added (5 cell(s), 1:12:23)
003028:0000 Title #2 was added (5 cell(s), 1:12:23)
003025:0000 Title #3 has length of 19 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003028:0000 Title #4 was added (6 cell(s), 1:12:15)
003028:0000 Title #5 was added (6 cell(s), 1:12:15)
DEBUG: Code 67109127 at VL^ylL[qTx}%vZ*L:121266189
Title skip vts=4 pgcn=1 hash=70C806819AEE6B57
DEBUG: Code 67109383 at VL^ylL[qTx}%vZ*L:121266189
Title skip vts=4 pgcn=2 hash=DE43892D573E667D
003027:0000 Title 2 in VTS 1 is equal to title 1 and was skipped
003027:0000 Title 2 in VTS 3 is equal to title 1 and was skipped
005014:0000 Saving 2 titles into directory N:/ARS/Video/convert/BANACEK_DISC_2
005005:0080 2 titles saved
005036:0104 Copy complete. 2 titles saved.
Application exited at Mon Jun 25 05:06:28 2018
#4 Post by Woodstock » Mon Jun 25, 2018 1:38 pm
It looks like this disk was authored differently - you have 4 single episodes, and no "play all" file.
"Play all" can be done multiple ways on both DVD and BD - it can be a consolidated "play list" file, like you've seen on the other disks, or entries in the menu system.
And yes, the way things are authored can change within a "set". The series "Bleach", which spans 360 episodes, alternated between "everything in one file, no separate episode files", "each episode in its own file", and "both single episode and all-in-one" over its release history. Several sets switched between disks in a 2- or 3-disk set.
aspartz
#5 Post by aspartz » Mon Jun 25, 2018 7:15 pm
Woodstock wrote:It looks like this disk was authored differently - you have 4 single episodes, and no "play all" file.
There appears to be 4 titles but two of them are duplicates of others, so in effect, I have on two of the three episodes.!
