Missing titles on older Banacek DVD
aspartz
Post by aspartz »
I have a 2008 TVGuide release of Banacek season 2.
Disc two is supposed to have 3 independent titles and a 4th that is all three combined.
When I try to convert this with MakeMKV only the first two titles are shown. There are no unreadable sectors. The disc plays correctly on PowerDVD.
Any Ideas?
Re: Missing titles on older Banacek DVD
The FAQ link in my signature will help you gather the information Mike will need to help on this. You can send it to support@makemkv.com
You could also post the debug log here for us non-Mike people to look at, and maybe we can see the problem. Just put it between "code" tags, and include it in a reply.
aspartz
Post by aspartz »
Debug log started at Mon Jun 25 04:51:08 2018 , written by MakeMKV v1.12.2 win(x64-release)
001005:0000 MakeMKV v1.12.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\aspartz/MakeMKV_log.txt
003028:0000 Title #1 was added (5 cell(s), 1:12:23)
003028:0000 Title #2 was added (5 cell(s), 1:12:23)
003025:0000 Title #3 has length of 19 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003028:0000 Title #4 was added (6 cell(s), 1:12:15)
003028:0000 Title #5 was added (6 cell(s), 1:12:15)
DEBUG: Code 67109127 at VL^ylL[qTx}%vZ*L:121266189
Title skip vts=4 pgcn=1 hash=70C806819AEE6B57
DEBUG: Code 67109383 at VL^ylL[qTx}%vZ*L:121266189
Title skip vts=4 pgcn=2 hash=DE43892D573E667D
003027:0000 Title 2 in VTS 1 is equal to title 1 and was skipped
003027:0000 Title 2 in VTS 3 is equal to title 1 and was skipped
005014:0000 Saving 2 titles into directory N:/ARS/Video/convert/BANACEK_DISC_2
005005:0080 2 titles saved
005036:0104 Copy complete. 2 titles saved.
Application exited at Mon Jun 25 05:06:28 2018
It looks like this disk was authored differently - you have 4 single episodes, and no "play all" file.
"Play all" can be done multiple ways on both DVD and BD - it can be a consolidated "play list" file, like you've seen on the other disks, or entries in the menu system.
And yes, the way things are authored can change within a "set". The series "Bleach", which spans 360 episodes, alternated between "everything in one file, no separate episode files", "each episode in its own file", and "both single episode and all-in-one" over its release history. Several sets switched between disks in a 2- or 3-disk set.
aspartz
Post by aspartz »
Woodstock wrote:It looks like this disk was authored differently - you have 4 single episodes, and no "play all" file.
There appears to be 4 titles but two of them are duplicates of others, so in effect, I have on two of the three episodes.!
