Trying to rip the newer It movie. This has been out for awhile so I figured it wouldn't be a problem.
I have the dump file but didn't see anyway to attach it.
Any ideas with this info:
MakeMKV v1.12.2 win(x64-release) started
Saved SD dump file as C:\Users\Huttzilla/.MakeMKV/dump_SD_DCC6303281512ECDDF4D.tgz
Saved AACS dump file as C:\Users\Huttzilla/.MakeMKV/MKB20_v61_IT_D375.tgz
Product: BD-RE BH16NS40
Revision: 1.02
Serial number: SIK9DH6LG563
Firmware date: 2117-03-10 16:37:
Highest AACS version: 61
Disc Information
Label: IT
Timestamp: 2017-11-22 19:04:01
Data capacity: 60.63 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
My first 4k attempt... and failed
Re: My first 4k attempt... and failed
as I pressed the submit I saw the file attachment option...
- dump_SD_DCC6303281512ECDDF4D.tgz
- dump file
- (1.31 MiB) Downloaded 764 times
Mike doesn't look for dump files here - it's best to email them to svq@makemkv.com for analysis.
Email sent.Woodstock wrote:Mike doesn't look for dump files here - it's best to email them to svq@makemkv.com for analysis.
Thank you.
Shouldn't this be moved to the UHD forum, not the Linux forum,
especially since the user is running Windows?
Yes, it should be, and now has been.
Oops... sorry. I've been sick the last few days. Maybe still a little out of it. No idea why I posted in the Linux forum!!xr200 wrote:Shouldn't this be moved to the UHD forum, not the Linux forum,
Will do.. thanks!
