My first 4k attempt... and failed
anddes
Post by anddes »
Trying to rip the newer It movie. This has been out for awhile so I figured it wouldn't be a problem.
I have the dump file but didn't see anyway to attach it.
Any ideas with this info:
MakeMKV v1.12.2 win(x64-release) started
Saved SD dump file as C:\Users\Huttzilla/.MakeMKV/dump_SD_DCC6303281512ECDDF4D.tgz
Saved AACS dump file as C:\Users\Huttzilla/.MakeMKV/MKB20_v61_IT_D375.tgz
Product: BD-RE BH16NS40
Revision: 1.02
Serial number: SIK9DH6LG563
Firmware date: 2117-03-10 16:37:
Highest AACS version: 61
Disc Information
Label: IT
Timestamp: 2017-11-22 19:04:01
Data capacity: 60.63 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
anddes
Re: My first 4k attempt... and failed
Post by anddes »
as I pressed the submit I saw the file attachment option...
dump file
(1.31 MiB) Downloaded 920 times
Mike doesn't look for dump files here - it's best to email them to svq@makemkv.com for analysis.
anddes
Post by anddes »
Woodstock wrote:Mike doesn't look for dump files here - it's best to email them to svq@makemkv.com for analysis.
Email sent.
Thank you.
xr200
Post by xr200 »
Shouldn't this be moved to the UHD forum, not the Linux forum,
especially since the user is running Windows?
Yes, it should be, and now has been.
st4evr
Post by st4evr »
anddes
Post by anddes »
xr200 wrote:Shouldn't this be moved to the UHD forum, not the Linux forum,
Oops... sorry. I've been sick the last few days. Maybe still a little out of it. No idea why I posted in the Linux forum!!
Will do.. thanks!
