Beware MHA season two part one disc 1
jacknifed47
Post by jacknifed47 »
Tried backing up My Hero Academia Season two Part one Disc one, and it resulted in a "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive" error leaving me unable to use any blurays with MKV.
Re: Beware MHA season two part one disc 1
Did MakeMKV save a AACS dump of the disk? You'll find it in your MakeMKV directory, with a file name that starts with MKBv.
If it did, send that file to support@makemkv.com for Mike to review.
jacknifed47
Woodstock wrote:Did MakeMKV save a AACS dump of the disk? You'll find it in your MakeMKV directory, with a file name that starts with MKBv.
Oh it did and I already sent the file for review. I just wanted to make sure that it was up here for others to know about so that they won't essentially brick their MKV.
What was the version after the MKBv ?
jacknifed47
Never mind
I'm an ape. So used to automatic updates, that I ignore the update text on a regular basis.
Will delete the thread by tomorrow to prevent confusion.
You can't delete it, but you could modify the title on your first message to show that it's resolved.
