UHD Ripping failing all of a sudden...
Liersi
Re: UHD Ripping failing all of a sudden...
Post by Liersi » Fri Jun 22, 2018 5:18 pm
Hey guys, I thought I'd add my question to this thread rather than create another. It's about the same issue, errors ripping UHDs.
First off, thank you everyone in this thread. You saved me a lot of headaches with this "but it's new! CLEAN THE DISC ANWAY!" routine. It's absolutely true. As is what jonghotti wrote about fickle hardware. Which brings me to my question: when MakeMKV pops up an error (hash check error or read error) but proceeds to complete the backup, what am I looking at? A bit perfect rip or one with an error in it? Asking in general here as it has me confused. Usually it aborts and doesn't complete on error.
Thankful for any insight.
jonghotti
Post by jonghotti » Fri Jun 22, 2018 5:32 pm
Liersi wrote:Hey guys, I thought I'd add my question to this thread rather than create another. It's about the same issue, errors ripping UHDs.
Hash check I definitely redo it, after cleaning the disc again :-)
Read errors never seem to come in singles for me, it’ll be like 20
of them followed by an abort.
My situation gets a little more complicated in that I’m always changing out hardware as I’ve got at least 20 drives to test. And until I’ve got the entire collection backed up it would be silly to waste that time using the same disc to test with. Would reduce a variable sure.
Once you get used to the if it errors clean it routine life gets easier. I built up a new PC just for making MakeMKV backups and am doing the launch two MakeMKV instances using two optical drives to two hard drives it works like a fucking charm!!! I am so loving this program right now!
Liersi
Post by Liersi » Fri Jun 22, 2018 6:20 pm
jonghotti wrote: Hash check I definitely redo it, after cleaning the disc again :-)
Thanks for the response.
The read error, right? That's what has me confused. I've never seen that and haven't reproduced it yet with a log. It's usually as you say, but this time it mentioned ONE, and completed fine. The hash check I figured like you and redid it right away. I'll see what I can make of the backup, otherwise clean again and rerun. This is turning out to be more of a fickle beast than I expected.
jonghotti
Post by jonghotti » Fri Jun 22, 2018 6:27 pm
If by that you mean rip roaring pain in the ass at times, I hear you. When things work, they work great! When they don't, it's like one long continuous fuckup :)
At least in my experience.....
spaded21
Post by spaded21 » Sun Jun 24, 2018 10:25 pm
Any other tips for cleaning discs or getting them to read? I have tried cleaning my drive with one of those discs with the little brushes on it and applying rubbing alcohol to the problem discs and buffing them clean with a fresh microfiber towel, but I have still have 3 new UHDs that I can't rip. Most blu-rays and UHDs rip fine so I don't think it's the drive.
rivey
Post by rivey » Sun Jun 24, 2018 11:15 pm
spaded21 wrote:Any other tips for cleaning discs or getting them to read? I have tried cleaning my drive with one of those discs with the little brushes on it and applying rubbing alcohol to the problem discs and buffing them clean with a fresh microfiber towel, but I have still have 3 new UHDs that I can't rip. Most blu-rays and UHDs rip fine so I don't think it's the drive.
What are the titles of the three discs you are having problems with. Can you post copies of the logs for those three discs?
jonghotti
Post by jonghotti » Sun Jun 24, 2018 11:31 pm
Lemme guess which ones:
1. Thor:Ragnarok
2. The Revenant
3. Planet Earth II, disc 2
Oh wait, those are my top 3 pains in the asses.
I've never cleaned a drive other than blowing it with compressed air. For discs I have a pump bottle of LCD screen cleaner and a stack of microfiber towels.
Having multiple optical drives to use is also key.
cameron2
Post by cameron2 » Sat Jun 01, 2019 11:53 pm
I've had the same problem with 2 copies of Planet Earth II disc 2 :(
eddified
Post by eddified » Mon Sep 23, 2019 3:56 am
I had errors reading Planet Earth II Disc 2, UHD. I've heard there is a backup method, does that work to get the same result - (an .mkv file)?
jonghotti
Post by jonghotti » Mon Sep 23, 2019 4:10 am
Another user who has gone through two copies of Planet Earth II disc 2 trying to find one that would rip lol. What is it about this disc?
